2022-04-07 | testsuites/libtests/[d-o]*: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-09-29 | 2011-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c: Add HAVE_CONFIG_H. | |||||
2011-03-14 | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+35 | |
* Makefile.am, configure.ac: Add test for Mouse Parser Engine (Microsoft Mouse paths) and Serial Mouse Driver. * mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c, mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c, mouse01/serial_mouse_config.c: New files. |
