* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+11 |
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-31 | 2 | -277/+8 |
| | | | | This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f. | ||||
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-31 | 2 | -8/+277 |
| | | | | This reverts commit 6a5bd1c65c005457455db344f2ee831d7a5cf99b. | ||||
* | Revert "Revert "libtests/math*: Avoid generated files"" | Ralf Corsépius | 2012-05-24 | 2 | -277/+8 |
* | Revert "libtests/math*: Avoid generated files" | Ralf Corsépius | 2012-05-23 | 2 | -8/+277 |
* | libtests/math*: Avoid generated files | Sebastian Huber | 2012-05-22 | 2 | -277/+8 |
| | | | | Use C pre-processor instead of shell commands. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 2 | -6/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-13 | 2 | -16/+16 |
| | | | | | | * math/init.c, mathf/init.c, mathl/init.c: Move configuration section. * math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate. * math/domath.in: Generate domath* prototype. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 2 | -0/+8 |
* | 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-02-14 | 1 | -2/+1 |
| | | | | * math/init.c, mathf/init.c, mathl/init.c: Now run. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -164/+2 |
| | | | | * math/math.scn, mathf/mathf.scn, mathl/mathl.scn: Regenerate. | ||||
* | New (Split out from math/). | Ralf Corsepius | 2011-02-02 | 5 | -0/+544 |
