* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -7/+9 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 1 | -0/+43 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 6 | -10/+8 |
* | Fixed verificaiton checks to call correct macro if dispatch is disabled. | Jennifer Averett | 1999-11-15 | 1 | -7/+12 |
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 1 | -0/+3 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 3 | -4/+5 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 2 | -4/+29 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 7 | -0/+326 |
