* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -7/+9 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 1 | -1/+0 |
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 1 | -0/+43 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 7 | -12/+9 |
* | Changed asserts to tmmacros. | Jennifer Averett | 1999-11-16 | 2 | -8/+7 |
* | + Added check that a task could be sent to a dormant state | Jennifer Averett | 1999-11-15 | 4 | -12/+94 |
| | | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 1 | -1/+3 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 3 | -4/+4 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 4 | -9/+23 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 8 | -0/+353 |
