path: root/testsuites/itrontests/itrontask03 (follow)
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | * itronhello/Makefile.am, itronmbf01/Makefile.am, itronmbox01/Makefile.am, itronsem01/Makefile.am, itrontask01/Makefile.am, itrontask02/Makefile.am, itrontask03/Makefile.am, itrontask04/Makefile.am, itrontime01/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+9
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Fixed warnings.Joel Sherrill2000-01-041-1/+0
* Uncommitted remains of a previous patch from Ralf CorsepiusJoel Sherrill1999-11-301-0/+43
| | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake.
* + Updated copyright information.Jennifer Averett1999-11-177-12/+9
* Changed asserts to tmmacros.Jennifer Averett1999-11-162-8/+7
* + Added check that a task could be sent to a dormant stateJennifer Averett1999-11-154-12/+94
| | | | | | | | then sta_tsk used to restart the task to its initial state. + Added calls to ref_tsk to yellow paths for suspended and ready but not running tasks. + Fixed output file to correctly state test name + Added priority of preempt to the header file. Allows ref_tsk verification.
* + Added comments on paths tested.Joel Sherrill1999-11-121-1/+3
* Test name changed to reflect placement after merger.Joel Sherrill1999-11-123-4/+4
* General cleanup. Test documentation improved. The message buffer testJoel Sherrill1999-11-104-9/+23
| | | | | prints a message instead of actually testing since the message buffer implementation is not in yet.
* Merged tests from Task group.Joel Sherrill1999-11-098-0/+353
