path: root/testsuites/configure.ac (follow)
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-1/+1
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-2/+2
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-221-3/+0
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-131-4/+0
| | | | * configure.ac: Remove AMPOLISH3 (Unused).
* 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-091-4/+4
| | | | * configure.ac: Fix config-variables of conditionally built subdirs.
* 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-091-12/+9
| | | | * configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* Add AMPOLISH3. Remove support/.Ralf Corsepius2005-11-091-1/+4
* Sync POSIX and ITRON magic with cpukit.Ralf Corsepius2005-11-071-3/+3
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-1/+1
| | | | * configure.ac: Require automake > 1.9.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-251-1/+1
| | | | * configure.ac: Add 2nd arg to RTEMS_TOP.
* 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-191-1/+1
| | | | | | | | * configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-1/+0
| | | | * configure.ac: Remove subdir tools.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-101-1/+1
| | | | * configure.ac: Reflect having moved to testsuites/.
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-221-1/+0
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-021-1/+0
| | | | | | | | | * configure.ac:Remove RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-221-4/+9
| | | | | | * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples. * configure.ac: Reflect changes above.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-1/+0
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-161-1/+0
| | | | * configure.ac: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+64
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
