* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -4/+0 |
| | | | | * configure.ac: Remove AMPOLISH3 (Unused). | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -4/+4 |
| | | | | * configure.ac: Fix config-variables of conditionally built subdirs. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -12/+9 |
| | | | | * configure.ac: Apply RTEMS_CHECK_CPUOPTS. | ||||
* | Add AMPOLISH3. Remove support/. | Ralf Corsepius | 2005-11-09 | 1 | -1/+4 |
* | Sync POSIX and ITRON magic with cpukit. | Ralf Corsepius | 2005-11-07 | 1 | -3/+3 |
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -1/+1 |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | ||||
* | 2004-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 1 | -1/+1 |
| | | | | | | | | * configure.ac: AC_CONFIG_SRCDIR([PROBLEMS]). * aclocal/check-custom-bsp.m4: Sync with c/src/aclocal. * aclocal/project-root.m4: Remove obsolete comments. * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT. * aclocal/rtems-top.m4: Rework. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 1 | -1/+0 |
| | | | | * configure.ac: Remove subdir tools. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -2/+2 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-10 | 1 | -1/+1 |
| | | | | * configure.ac: Reflect having moved to testsuites/. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 1 | -1/+0 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-02 | 1 | -1/+0 |
| | | | | | | | | | * configure.ac:Remove RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. | ||||
* | 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-22 | 1 | -4/+9 |
| | | | | | | * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples. * configure.ac: Reflect changes above. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -1/+1 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -1/+0 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -1/+1 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-16 | 1 | -1/+0 |
| | | | | * configure.ac: Remove ENABLE_GCC28. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -2/+2 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+64 |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. |
