path: root/testsuites/aclocal/rtems-bsp-includes.m4 (unfollow)
2021-11-29*/aclocal/*: Remove remnants of autoconf/automae build systemJoel Sherrill1-13/+0
Updates #4081.
2018-01-25Remove make preinstallChris Johns1-0/+13
