* support/.cvsignore: New file.
* Makefile.am: Don't preinstall support/include headers.
* configure.ac: Fix config-variables of conditionally built subdirs.
* aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-posix.m4,
aclocal/check-tests.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4: Remove (Unused).
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* aclocal/prog-cc.m4: Apply cpukit_root, project_root to set up
GCCSPECS.
* aclocal/check-cpuopts.m4: Apply cpukit_root, project_root to set
up temporary CPPFLAGS to compile check cpuopts.h.
* aclocal/rtems-top.m4: Add --enable-cpukit-root,
--enable-project-root. Remove --with-project-root.
Fix --enable-rtems-root.
* automake/compile.am, aclocal/env-rtemsbsp.m4:
Assume PROJECT_ROOT to contain RTEMS_BSP.
* Makefile.am: Merge-in support/Makefile.am
* configure.ac: Add AMPOLISH3. Remove support/.
* aclocal/check-cpuopts.m4: Add config.cache support.
* aclocal/check-cxx.m4: Remove CPLUS_LD_LIBS.
* automake/compile.am: Eliminate PROJECT_LIB.
Remove START_FILE, OBJS from LINK_FILES.
* aclocal/check-cpuopts.m4: New.
* automake/compile.am: Remove RTEMS_CPPFLAGS, RTEMS_CFLAGS,
RTEMS_CXXFLAGS.
* aclocal/gcc-isystem.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4: Remove GCCSPECS.
* aclocal/prog-cc.m4: Add GCCSPECS. Remove RTEMS_CPPFLAGS.
Remove RTEMS_CFLAGS.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
Remove RTEMS_GCC_PIPE. Remove RTEMS_GCC_SPECS.
* aclocal/gcc-pipe.m4: Remove (Unused).
* aclocal/gcc-specs.m4: Remove (Unused).
* aclocal/env-rtemsbsp.m4: Merge RTEMS_BSP_SPECS and
GCC_SPECS into GCCSPECS.
* automake/compile.am: Remove RTEMS_BSP_SPECS, GCC_SPECS.
Don't manually set up GCCSPEC (Now setup from inside configure).
Remove RTEMS_RELLDFLAGS (Used).
* automake/compile.am: Remove CCAS support.
* aclocal/multilib.m4: Remove (Unused).
* aclocal/check-multiprocessing.m4: Don't require
RTEMS_ENABLE_MULTILIB.
* aclocal/env-rtemsbsp.m4: Don't provide MULTILIB conditional.
* aclocal/check-posix.m4: Sync with cpukit.
* configure.ac: Sync POSIX and ITRON magic with cpukit.
* aclocal/config-subdirs.m4, aclocal/path-ksh.m4,
aclocal/quoting.m4, aclocal/tool-paths.m4: Remove.
* automake/compile.am: Remove depend.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
* automake/compile.am: Take contents of amcompile.am.
* automake/amcompile.am: Remove.
* automake/amcompile.am: New.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
* aclocal/prog-cxx.m4: Re-add am__fastdepCXX conditional.
* aclocal/rtems-flags.m4: Remove (Unused).
Remove CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V.
Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS.
* aclocal/prog-cxx.m4: Let CXXFLAGS default to CFLAGS.
Don't invoke _RTEMS_FLAGS to set up RTEMS_CXXFLAGS.
Remove am__fastdepCXX conditional.
* automake/compile.am: Remove CLEANDIRS (Unused).
Remove DEFS (Implicitly handled by automake).
* automake/compile.am: Remove CONFIG.CC (Unused).
Remove CPPFLAGS, CFLAGS, CXXFLAGS, ASFLAGS (Implicitly handled by
automake). Add CCAS. Use AM_*FLAGS = RTEMS_*FLAGS.
Remove LIB_VARIANT from LINK_*.
Cleanup comments.
* automake/compile.am: Remove AS, ASCOMPILE, make-rel (Unused).
Remove build-variants. Hard-code ARCH=o-optimize.
* aclocal/enable-itron.m4, aclocal/check-itron.m4:
Allow building itron for unix.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* aclocal/rtems-top.m4: Add project_top/with_project_top processing.
* aclocal/rtems-top.m4: s/RTEMS_RTEMS/RTEMS_ROOT (typo).
* aclocal/check-custom-bsp.m4: Fix minor typo.
* aclocal/rtems-top.m4: Add rtems_rootdir.
* aclocal/check-custom-bsp.m4: Check for $RTEMS_BSP.cfg in $rtems_rootdir.
* aclocal/rtems-top.m4: Add 2nd arg to RTEMS_TOP.
Rework with_project_root/PROJECT_ROOT and with_project_top/PROJECT_TOPdir.
Add --enable-rtems-root. Rework RTEMS_ROOT.
* aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/rtems-test-no-pause.m4: Autoupdate to autoconf-2.59.
