2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-07-26 | build: Move RISCV_MAXIMUM_EXTERNAL_INTERRUPTS | Sebastian Huber | 1 | -1/+1 | |
2022-07-04 | build: Add cppflags, cflags, cxxflags to groups | Sebastian Huber | 1 | -0/+3 | |
Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670. | |||||
2021-11-30 | build: Use common objects item for get memory | Sebastian Huber | 1 | -0/+2 | |
2021-04-07 | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 1 | -2/+0 | |
Update #3850 | |||||
2020-11-09 | Add networking support for griscv bsp | Jiri Gaisler | 1 | -0/+2 | |
* Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf | |||||
2020-09-14 | build: Alternative build system based on waf | Sebastian Huber | 1 | -0/+46 | |
Update #3818. |
