* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | build: Move RISCV_MAXIMUM_EXTERNAL_INTERRUPTS | Sebastian Huber | 2022-07-26 | 1 | -1/+1 |
* | build: Add cppflags, cflags, cxxflags to groups | Sebastian Huber | 2022-07-04 | 1 | -0/+3 |
| | | | | | | | Propagate the group defined cppflags, cflags, and cxxflags from parent groups to child items through the build item context. Update #4670. | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -0/+2 |
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2/+0 |
| | | | | Update #3850 | ||||
* | Add networking support for griscv bsp | Jiri Gaisler | 2020-11-09 | 1 | -0/+2 |
| | | | | | | | * Only GRETH device supported for now * Fix endian problem in GRETH driver * Remove SPARC assembly from greth.c * Builds with both autoconf and waf | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+46 |
Update #3818. |
