path: root/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml (follow)
* bsps: Use header file for GIC architecture supportSebastian Huber2020-12-231-1/+0
| | | | | | This avoids a function call overhead in the interrupt dispatching. Update #4202.
* bsps/arm: Unify ARM Generic Timer optionsSebastian Huber2020-12-101-4/+4
| | | | Update #4202.
* spec: Move zynq-uart into its own objectKinsey Moore2020-12-041-0/+2
| | | | | | | Currently, zynq-uart code is always built and has some requirements for BSPs that use it. Instead of making all BSPs satisfy that requirement or working around it by setting defaults, this moves the zynq-uart code into its own spec build object so it can be included if needed.
* Add AArch64 ZynpMP BSPKinsey Moore2020-12-041-1/+1
| | | | | | | | This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC (ZynqMP) family of chips. It is configured to be usable on the Qemu ZCU102 machine definition and should be almost trivially portable to ZynqMP development boards and custom hardware. It is also configured to be usable with libbsd.
* bsps: Move ARM GICv2 driver to bsps/sharedKinsey Moore2020-12-021-1/+2
| | | | | This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64 code.
* bsps: Move zynq-uart to bsps/sharedKinsey Moore2020-12-021-2/+0
| | | | | This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to accomodate use by AArch64 BSPs.
* bsps: Break out AArch32 portions of GPT driverKinsey Moore2020-10-051-1/+5
| | | | | | This breaks AArch32-specific portions of the ARM GPT driver into their own file so that the generic code can be moved for reuse by other architectures.
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+95
Update #3818.
