Updates #4321
Updates #4320
Update #4267.
Use the Python sorted() function to sort the "source" lists.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
- Disabled by default
- Enable using ARM_MMU_USE_SMALL_PAGES option
Close 4192.
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
Update #3818.
