* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 1 | -1/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 1 | -0/+1 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | arm/fvp: New BSP | Sebastian Huber | 2020-12-23 | 1 | -0/+17 |
This BSP supports the Arm Fixed Virtual Platform. Only the Cortex-R52 processor configuration is supported by the BSP. It should be easy to add support for other variants if needed. Update #4202. |
