brains GmbH.
Use the existing WRITE_SR() abstraction to access the interrupt group 0 and 1
enable registers. This fixes the build for the AArch32 target.
Add BSP options which define the initial values of CPU Interface registers.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Separate the Interrupt Manager implementation from the generic Arm GICv3
support. Move parts of the Arm GICv3 support into a new header file. This
helps to support systems with a clustered structure in which multiple GICv3
instances are present. For example, two clusters of two Cortex-R52 cores where
each cluster has a dedicated GICv3 instance.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Set the VBAR to the vector table in the start section before
bsp_start_hook_0() is called to earlier handle exceptions in RTEMS.
Set the VBAR to the normal vector table in start.S for the main
processor. Secondary processors set it in bsp_start_hook_0().
Update #4202.
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to
accomodate use by AArch64 BSPs.
This breaks out AArch32-specific code so that the shared GICv3 code can
be reused by other architectures.
This UART driver is now needed for BSPs other than ARM.
Update #3818.
