* | bsps/shared: Add Xilinx-AXI SPI driver to waf | Jan Sommer | 2021-03-30 | 1 | -0/+2 |
| | | | | Updates #4321 | ||||
* | bsps/xilinx_zynq: Add SPI driver to waf | Jan Sommer | 2021-03-10 | 1 | -0/+2 |
| | | | | Updates #4320 | ||||
* | spec: Move zynq-uart into its own object | Kinsey Moore | 2020-12-04 | 1 | -0/+2 |
| | | | | | | | Currently, zynq-uart code is always built and has some requirements for BSPs that use it. Instead of making all BSPs satisfy that requirement or working around it by setting defaults, this moves the zynq-uart code into its own spec build object so it can be included if needed. | ||||
* | Add AArch64 ZynpMP BSP | Kinsey Moore | 2020-12-04 | 1 | -0/+44 |
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC (ZynqMP) family of chips. It is configured to be usable on the Qemu ZCU102 machine definition and should be almost trivially portable to ZynqMP development boards and custom hardware. It is also configured to be usable with libbsd. |
