Replace the BSP_CONSOLE_MINOR BSP option for the Xilinx Zynq BSPs with the new
BSP option ZYNQ_UART_KERNEL_IO_BASE_ADDR. Move the kernel I/O support to a
shared file.
The objxilinxsupport build object was accidentally included twice in
some of the ZynqMP BSPs by two different drivers that required it. This
commit manually deduplicates the inclusions by moving that inclusion to
the BSP. Duplication of object inclusions is considered a bug and can
cause race conditions in the build system.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Always start the executive in Exception Level 1, Non-Secure mode.
If we boot in EL3 Secure with GICv3 then we have to initialize
the distributor and redistributor to set up G1NS interrupts
early in the boot sequence before stepping down from EL3S to EL1NS.
Now there is no need to distinguish between secure and non-secure
world execution after the primary core boots, so get rid of the
AARCH64_IS_NONSECURE configuration option.
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Added I2C drivers for ZynqMP and updated build system accordingly.
This reverts commit 10041a4cfc00d5f6876d3d6cfc30c23347b4cf42.
This type of configuration does not belong in RTEMS and is better
constrained to libbsd where the defines are actually being used.
Provide the options necessary to enable any combination of CGEM ethernet
interfaces in LibBSD. The default is still CGEM3, so this should
continue to operate as expected on typical Zynq Ultrascale+ MPSoC
development hardware.
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Updates #4321
Updates #4320
Currently, zynq-uart code is always built and has some requirements for
BSPs that use it. Instead of making all BSPs satisfy that requirement or
working around it by setting defaults, this moves the zynq-uart code
into its own spec build object so it can be included if needed.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
