* gccnewlib/gccnewlib.add, gdb/gdb.add: Append %_bindir to PATH
only if %_prefix != /usr.
* configure.ac: Remove GCC3NEWLIBVERS, BINUTILSVERS, GDBVERS.
* binutils/Makefile.am: Generate unversioned *binutils.spec.
* gccnewlib/Makefile.am: Generate unversioned *gcc-newlib.spec.
* gdb/Makefile.am: Generate unversioned *gdb.spec.
* binutils/target-binutils.add: Don't own %{_mandir}/man1 for
%_prefix == /usr.
* binutils/binutils.add: Remove dlltool, nlmconv, windres man pages.
* common/common.add.in: Remove Vendor:. Remove Distribution:.
* Makefile.am, autotools/Makefile.am, binutils/Makefile.am
cpukit/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am
rtems/Makefile.am: Rename *.spec into @rpmprefix@*.spec.
* binutils/base-binutils.add, binutils/binutils.add,
binutils/target-binutils.add, common/common.add.in,
cpukit/rtems-cpukit.add, cpukit/target-cpukit.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add,
gccnewlib/target-libc.add, gccnewlib/target-objc.add,
gdb/base-gdb.add, gdb/gdb.add, gdb/target-gdb.add,
rtemsdoc/rtemsdoc.add, rtemsdoc/supplement.add.in,
rtemsdoc/templ.add.in, rtems/rtems-source.add:
Replace %{rpmprefix} with @rpmprefix@.
* cpukit/mkspec.in, rtems/mkspec.in: Propagate @rpmprefi@.
* gccnewlib/Makefile.am: Use target-libc.add
* gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add,
gccnewlib/target-libc.add: Misc. fixes.
* gdb/gdb.add: Remove Packager:.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcc.add,
gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add,
gccnewlib/target-gnat.add, gccnewlib/target-objc.add:
Switch to using %gcc_version.
* binutils/binutils.add: Remove Packager:.
* binutils/target-binutils.add: Further adaptations to /usr.
* gccnewlib/target-c++.add, gccnewlib/target-g77.add,
Fix directory ownerships.
* gccnewlib/target-libc.add: New.
* gccnewlib/target-gcc.add: Add Requires/Provides *-newlib/*-libc.
* gccnewlib/gccnewlib.add: Add Requires/Provides *-newlib/*-libc.
gccnewlib/gccnewlib.add, gccnewlib/target-c++.add,
gccnewlib/target-g77.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Use gccnewlib_version.
Cosmetics. Minor cleanups.
* gccnewlib/base-gcc.add: Remove %_includedir.
* gccnewlib/base-g77.add: Remove %_mandir.
Remove %{gcc_target}-g77.1.
* gccnewlib/base-gfortran.add: Remove %_mandir.
Remove %{gcc_target}-gfortran.1.
* gccnewlib/gccnewlib.add: Remove Packager:.
Add %gccnewlib_version.
* gccnewlib/target-c++.add: Remove %_bindir.
* gccnewlib/target-g77.add: Add %{gcc_target}-g77.1.
* gccnewlib/target-gcj.add: Remove %_bindir.
Remove %_mandir.
* gccnewlib/target-gfortran.add: Remove %_bindir.
Add %{gcc_target}-gfortran.1.
* gccnewlib/target-gnat.add: Remove %_bindir.
Remove %_mandir.
