path: root/scripts (follow)
* Add BuildRoot.Ralf Corsepius2005-12-294-1/+5
* 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-291-0/+3
| | | | | * gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add BuildRoot.
* 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-291-1/+3
| | | | | * cpukit/rtems-cpukit: Add BuildRoot. * gccnewlib/gccnewlib.add: Add BuildRoot.
* Add BuildRoot:Ralf Corsepius2005-12-291-0/+1
* 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-291-0/+2
| | | | | * binutils/binutils.add: Remove BuildRoot. Don't build infos for prefix==/usr.
* Remove BuildRoot. Don't build infos for prefix==/usr.Ralf Corsepius2005-12-291-4/+12
* 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-291-0/+1
| | | | * common/common.add.in: Remove BuildRoot.
* Remove BuildRoot.Ralf Corsepius2005-12-291-3/+0
* 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-291-0/+5
| | | | | * autotools/autoconf.add, autotools/automake.add: Add BuildRoot. Remove Packager.
* Add BuildRoot. Remove Packager.Ralf Corsepius2005-12-292-5/+4
* Cosmetics.Ralf Corsepius2005-12-221-7/+18
* Cosmetics to make rpmlint happy.Ralf Corsepius2005-12-226-6/+6
* Cosmetics.Ralf Corsepius2005-12-2110-18/+20
* Drop Epoch:, Packager:.Ralf Corsepius2005-12-211-2/+0
* 2005-12-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-212-11/+17
| | | | * gdb/gdb.add: Add URL:.
* 2005-12-19 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-191-0/+7
| | | | | | | * binutils/binutils.add: Add URL:. * gccnewlib/gccnewlib.add: Add URL:. Use Source50/Patch50 for newlib. * gccnewlib/mkspec.in: Use Source50/Patch50 for newlib.
* Use Source50/Patch50 for newlib.Ralf Corsepius2005-12-191-3/+3
* Add URL:.Ralf Corsepius2005-12-191-10/+12
* Add URL:.Ralf Corsepius2005-12-191-0/+1
* CosmeticsRalf Corsepius2005-12-199-2/+10
* Cosmetics.Ralf Corsepius2005-12-193-10/+13
* Add __os_install_post.Ralf Corsepius2005-12-184-0/+12
* Remove __os_install_post.Ralf Corsepius2005-12-181-3/+0
* 2005-12-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-181-0/+6
| | | | | | * common/common.add.in: Remove __os_install_post. * cpukit/rtems-cpukit.add, gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add __os_install_post.
* Remove Packager:Ralf Corsepius2005-12-181-1/+0
* 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-212-6/+14
| | | | | * gccnewlib/gccnewlib.add: Rename src.rpm back to gcc-newlib.src.rpm. Misc fixups.
* 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-211-0/+4
| | | | | | | * gccnewlib/target-c++.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add gccnewlib/target-objc.add: Add License.
* Add License.Ralf Corsepius2005-11-217-2/+13
* Re-sort sub-package fragments.Ralf Corsepius2005-11-211-6/+6
* Add License.Ralf Corsepius2005-11-215-1/+6
* 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-211-0/+6
| | | | | | * gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add: Add License.
* 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-313-7/+14
| | | | | | * gccnewlib/gccnewlib.add: Rename src.rpm to *-gcc.src.rpm. * gccnewlib/target-gcc.add: Reflect changes above. * gccnewlib/Makefile.am: Re-sort sub-package fragments.
* 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-152-0/+7
| | | | | * gccnewlib/gccnewlib.add: Pass CC="%__cc $RPM_OPT_FLAGS" to configure.
* 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-151-0/+5
| | | | | * gccnewlib/gccnewlib.add, gdb/gdb.add: Append %_bindir to PATH only if %_prefix != /usr.
* Append %_bindir to PATH only if %_prefix != /usr.Ralf Corsepius2005-09-152-0/+4
* 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-151-0/+7
| | | | | | | * configure.ac: Remove GCC3NEWLIBVERS, BINUTILSVERS, GDBVERS. * binutils/Makefile.am: Generate unversioned *binutils.spec. * gccnewlib/Makefile.am: Generate unversioned *gcc-newlib.spec. * gdb/Makefile.am: Generate unversioned *gdb.spec.
* Generate unversioned *gdb.spec.Ralf Corsepius2005-09-151-26/+26
* Generate unversioned *gcc-newlib.spec.Ralf Corsepius2005-09-151-24/+24
* Generate unversioned *binutils.spec.Ralf Corsepius2005-09-151-24/+24
* Remove GCC3NEWLIBVERS, BINUTILSVERS, GDBVERS.Ralf Corsepius2005-09-151-6/+0
* 2005-09-05 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-052-1/+6
| | | | | * binutils/target-binutils.add: Don't own %{_mandir}/man1 for %_prefix == /usr.
* 2005-09-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-031-0/+4
| | | | * binutils/binutils.add: Remove dlltool, nlmconv, windres man pages.
* Remove dlltool, nlmconv, windres man pages.Ralf Corsepius2005-09-031-0/+5
* New.Ralf Corsepius2005-09-031-0/+20
* 2005-09-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-022-3/+1
| | | | * common/common.add.in: Remove Vendor:. Remove Distribution:.
* 2005-09-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-021-0/+3
| | | | | | * Makefile.am, autotools/Makefile.am, binutils/Makefile.am cpukit/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am rtems/Makefile.am: Rename *.spec into @rpmprefix@*.spec.
* Rename *.spec into @rpmprefix@*.spec.Ralf Corsepius2005-09-027-107/+109
* 2005-09-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-09-021-0/+14
| | | | | | | | | | | | | | | | | * binutils/base-binutils.add, binutils/binutils.add, binutils/target-binutils.add, common/common.add.in, cpukit/rtems-cpukit.add, cpukit/target-cpukit.add, gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add, gccnewlib/target-c++.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add, gccnewlib/target-libc.add, gccnewlib/target-objc.add, gdb/base-gdb.add, gdb/gdb.add, gdb/target-gdb.add, rtemsdoc/rtemsdoc.add, rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in, rtems/rtems-source.add: Replace %{rpmprefix} with @rpmprefix@.
* Replace %{rpmprefix} with @rpmprefix@Ralf Corsepius2005-09-0227-102/+101
* Fix typoRalf Corsepius2005-09-021-1/+1
