* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 2 | -10/+25 | |
* | Generated files removed. | Joel Sherrill | 1999-10-20 | 11 | -307/+155 | |
* | Obsoleted. | Joel Sherrill | 1999-10-20 | 1 | -34/+0 | |
* | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 1999-10-20 | 4 | -473/+0 | |
* | Made this more binutils like. :) | Joel Sherrill | 1999-10-20 | 1 | -5/+9 | |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+104 | |
* | New files. | Joel Sherrill | 1999-10-20 | 2 | -0/+285 | |
* | Adding the infrastructure for gdb. | Joel Sherrill | 1999-10-20 | 10 | -47/+155 | |
* | Corrected typo. | Joel Sherrill | 1999-10-20 | 1 | -3/+3 | |
* | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -19/+90 | |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 28 | -213/+3357 | |
* | Committing changes before Ralf's changed. | Joel Sherrill | 1999-10-20 | 4 | -24/+92 | |
* | Left to build overnight. | Joel Sherrill | 1999-10-19 | 7 | -10/+123 | |
* | Made it easier to change version numbers. | Joel Sherrill | 1999-10-19 | 2 | -15/+21 | |
* | Now easier to modify version numbers in scripts. | Joel Sherrill | 1999-10-19 | 2 | -14/+20 | |
* | Easier to insert tool version number. | Joel Sherrill | 1999-10-19 | 2 | -20/+31 | |
* | Making sparc-rtems rpms available. | Joel Sherrill | 1999-10-18 | 3 | -2/+3 | |
* | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 1999-10-18 | 12 | -27/+788 | |
| | | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | |||||
* | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1999-10-15 | 7 | -0/+399 | |
help build RPMs. |
