* | Regenerated | Joel Sherrill | 1999-10-26 | 6 | -27/+34 | |
* | Patch generated from scripts-19991025-0.tar.gz from | Joel Sherrill | 1999-10-25 | 10 | -74/+143 | |
| | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages) | |||||
* | Regnenerated following update from Ralf. | Joel Sherrill | 1999-10-25 | 6 | -27/+34 | |
* | Merged scripts-19991022-0 changes from Ralf. | Joel Sherrill | 1999-10-25 | 10 | -122/+82 | |
* | Changed version number. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 | |
* | Now builds RPM without complete source. Each target is only 15K. | Joel Sherrill | 1999-10-21 | 6 | -9/+59 | |
* | Made the RTEMS version get substituted properly even though it is | Joel Sherrill | 1999-10-21 | 14 | -9/+27 | |
| | | | | | | not right yet. Now can specify rpm_build_root via setup. | |||||
* | Now can specify rpm_build_root via setup. | Joel Sherrill | 1999-10-21 | 1 | -2/+2 | |
| | | | | Changed package name so generated RPM would have a nicer name. | |||||
* | Added sh-rtemself and m68k-rtemself. | Joel Sherrill | 1999-10-21 | 10 | -143/+176 | |
* | Changes from Ralf with script-19991021-0. He fixed the %files | Joel Sherrill | 1999-10-21 | 19 | -135/+231 | |
| | | | | | | | | issue and has mkbspspec in a better state. user.cfg is now gone. There are some miscellaneous changes to buildall done by Joel to clean up the build process. | |||||
* | Shipping this all to Ralf. | Joel Sherrill | 1999-10-21 | 2 | -6/+7 | |
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 7 | -19/+42 | |
| | | | | functioned. | |||||
* | Moved stuff to rtems subdirectory and made sure the system still | Joel Sherrill | 1999-10-20 | 2 | -34/+37 | |
| | | | | | | functioned. Merged Ralf's changes into gccnewlib.spec.in. | |||||
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+50 | |
* | Miscellaneous improvements and cleanups committed so I can merge | Joel Sherrill | 1999-10-20 | 13 | -199/+35 | |
| | | | | Ralf's end of day version. | |||||
* | Moved rtems specific files into here. | Joel Sherrill | 1999-10-20 | 1 | -0/+80 | |
* | Moving things to an rtems subdirectory like the other tools. | Joel Sherrill | 1999-10-20 | 2 | -80/+0 | |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+177 | |
* | Added RPM release numbers. | Joel Sherrill | 1999-10-20 | 2 | -10/+25 | |
* | Generated files removed. | Joel Sherrill | 1999-10-20 | 11 | -307/+155 | |
* | Obsoleted. | Joel Sherrill | 1999-10-20 | 1 | -34/+0 | |
* | Obsoleted as they were distributed to subdirectories. | Joel Sherrill | 1999-10-20 | 4 | -473/+0 | |
* | Made this more binutils like. :) | Joel Sherrill | 1999-10-20 | 1 | -5/+9 | |
* | New file. | Joel Sherrill | 1999-10-20 | 1 | -0/+104 | |
* | New files. | Joel Sherrill | 1999-10-20 | 2 | -0/+285 | |
* | Adding the infrastructure for gdb. | Joel Sherrill | 1999-10-20 | 10 | -47/+155 | |
* | Corrected typo. | Joel Sherrill | 1999-10-20 | 1 | -3/+3 | |
* | Restored joel's changes after merging old version from Ralf. | Joel Sherrill | 1999-10-20 | 1 | -19/+90 | |
* | New version from Ralf. | Joel Sherrill | 1999-10-20 | 28 | -213/+3357 | |
* | Committing changes before Ralf's changed. | Joel Sherrill | 1999-10-20 | 4 | -24/+92 | |
* | Left to build overnight. | Joel Sherrill | 1999-10-19 | 7 | -10/+123 | |
* | Made it easier to change version numbers. | Joel Sherrill | 1999-10-19 | 2 | -15/+21 | |
* | Now easier to modify version numbers in scripts. | Joel Sherrill | 1999-10-19 | 2 | -14/+20 | |
* | Easier to insert tool version number. | Joel Sherrill | 1999-10-19 | 2 | -20/+31 | |
* | Making sparc-rtems rpms available. | Joel Sherrill | 1999-10-18 | 3 | -2/+3 | |
* | Working on being able to cut RPMs. It now appears that the process | Joel Sherrill | 1999-10-18 | 12 | -27/+788 | |
| | | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets. | |||||
* | Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts to | Joel Sherrill | 1999-10-15 | 7 | -0/+399 | |
help build RPMs. |
