* gdb/Makefile.am: Add avr, mips64.
Cosmetics.
* gdb/base-gdb.add: Reflect gdb-6.3 not shipping mmalloc.info*.
* gdb/target-gdb.add: Add support for gcc-6.3's gdbtui.
* gdb/mkspec.in: Add PATCH-magic.
Add gdb_suffix.
* binutils/binutils.add, binutils/mkspec.in, setup.def:
Add binutils_suffix.
* binutils/target-binutils.add: Preparations for binutils-2.16.
* gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, setup.def:
Add gcc_suffix. Add newlib_suffix.
* autotools/automake-rtems.spec.in: automake-1.9.5.
* gcc3newlib/Makefile.am: Remove sh-rtemself. Add sh-rtemscoff.
* gcc3newlib/gccnewlib.add: Disable Ada (Stil broken with GCC-4.0.0).
* gcc3newlib/gccnewlib.add: Change my email address.
Add tic4x-*.
* autotools/automake-rtems.spec.in: automake-1.9.4.
* setup.def: Include PowerPC patch to make C++ global constructors work
-- gcc 3.3.5/newlib-1.12.0 revision 2.
* setup.def: Update gcc to 3.3.5 and binutils to 2.15.
* autotools/autoconf-rtems.spec.in: Temporarily do not include
some of the documentation since it causes the RPM build to fail.
* binutils/Makefile.am, gcc3newlib/Makefile.am: Add mips64-rtems.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/gccnewlib.add,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: i960 obsoleted.
* binutils/binutils.add: Rename package from binutils-collection to
binutils. Cleanups.
* binutils/target-binutils.add: Reflect changes above.
* binutils/Makefile.am: Add avr. Reflect changes above.
* autotools/autoconf-rtems.spec.in: Cleanup for chroot'ed builds.
* autotools/automake-rtems.spec.in: automake-1.9.2.
* gcc3newlib/Makefile.am: Add avr-rtems*gcc.
* gcc3newlib/gccnewlib.add: Disable c++ for avr.
* autotools/automake.spec.in: automake-1.9.
* gcc3newlib/gccnewlib.add: gcc 3.4.0 is broken for embedded SPARC and
Ada. Until we can fix it, it is disabled.
* gcc3newlib/target-gnat.add: Fix path to gnat1.
* binutils/Makefile.am: Add sh-rtemscoff.
Remove sh-rtemself.
* binutils/binutils.add: BuildRequires flex.
* autotools/automake-rtems.spec.in: Automake 1.8.5.
* gcc3newlib/gccnewlib.add: Another attempt to make *info.gz
handling more robust.
* autotools/automake-rtems.spec.in: Upgrade to 1.8.4.
* Index: base-g77.add, base-gcc.add, base-gcj.add, base-gnat.add,
gccnewlib.add, target-c++.add, target-gcc.add, target-gcj.add:
Apply _infodir, _mandir. Gzip man pages.
Reflect gcc having fixed gccinstall.info.
* binutils/base-binutils.add: Apply _infodir.
Don't install libiberty. Misc. cleanups.
* binutils/binutils.add: Apply _infodir, _mandir.
Don't install libiberty. Gzip man pages. Misc. cleanups.
* binutils/target-binutils.add: Apply _mandir.
* autotools/automake-rtems.spec.in: Upgrade to 1.8.3.
* gcc3newlib/gccnewlib.add: Disable gnats.
Further preparations for gcc-3.4.0
* gcc3newlib/base-gcc.add, gcc3newlib/target-gnat.add,
gcc3newlib/base-gcj.add, gcc3newlib/target-gcj.add:
Reflect changes to gcc3newlib/gccnewlib.add.
* gcc3newlib/base-gcc.add, gcc3newlib/target-g77.add,
gcc3newlib/target-objc.add: Preps for gcc-3.4.0.
* gcc3newlib/target-gcc.add, gcc3newlib/target-c++.add:
* gcc3newlib/gccnewlib.add: Preps. for gcc-3.4.0.
Add %gcclib, %gccexec.
* binutils/base-binutils.add: Preparations for binutils-2.15.
PR 580/tools
* setup.def: Fix setup.def to match current reality.
* gdb/base-gdb.add: Add annotate.info.
* gdb/gdb.add: Remove info/dir.
* Makefile.am, gdb/Makefile.am: Cosmetics.
* setup.def, gdb/gdb.add: gdb 6.0 RPMs built.
* ChangeLog: Replace RTEMS user account with Joel.
* setup.def, gdb/base-gdb.add, gdb/gdb.add: Building a gcc 3.2.3 i960
gcc and updating gdb to 5.3.
* configure.ac, setup, setup.def: Remove now unused vars.
* mkgccnewlibspec.in, gccnewlib/.cvsignore, gccnewlib/HISTORY,
gccnewlib/Makefile.am, gccnewlib/README, gccnewlib/base-chill.add,
gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/gccnewlib.add, gccnewlib/header.add,
gccnewlib/target-chill.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-objc.add: Remove (Obsolete).
* configure.ac, Makefile.am: Reflect changes above.
* gcc3newlib/gcc3newlib.add: Remove info/dir.
Cosmetics.
* setup.def: Adapt to what Joel already ships -
gcc3_version=3.3.2, gcc3_patch_version=20031216,
gcc3newlib_rpm_release=3
* configure.ac: Remove rtemsdoc/mkspec. Add RTEMS_RPM_RELEASE.
* rtemsdoc/.cvsignore: Reformat.
* Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to
rtems-source.add, Use rtems_source_spec_DEPS instead of
rtems_source_spec_DEPENDENCIES (Conflicts with automake internals).
* rtems/rtems-source.add: Add RTEMS_RPM_RELEASE.
* rtemsdoc/mkspec.in: Remove.
* rtemsdoc/Makefile.am: Reworked.
* rtemsdoc/header.add: Update Copyright notice.
* rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE.
Add %{rpmgroup}. Remove bzip-ing *.ps.
* rtemsdoc/supplement.add.in: Add %{rpmgroup}.
* rtemsdoc/templ.add.in: Add %{rpmgroup}.
* rtems/rtems-source.add: Require automake-1.8.2, autoconf-2.59.
* rtems/rtems-source.add: New.
* Makefile.am: Add rtems/rtems-source.spec handling.
* configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]).
* common/common.add.in: Use www.rtems.com as Vendor.
* configure.ac: Use RTEMS_ENABLE_RPMPREFIX.
cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am,
gdb/Makefile.am: Attempt to convert all c4x-rtems references to
tic4x-rtems. Left the rtems documentation alone.
* configure.ac: Enable OS versioning by default for 4.7 branch.
* setup.def: Update binutils RPM version and build new gcc 3.2.3 RPMs.
* autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in:
Update for new tool spin.
* scripts/automake.spec.in: 1.8.2.
* scripts/automake.spec.in: 1.8.1.
Add Patch0 automake-1.8.1-rtems-20040112-1.diff.
Add defattr, URL:-tag.
