* gccnewlib/gccnewlib.add: Remove vxaddr2line.
Further minor cleanup.
* binutils/binutils.add:
Special-case _prefix=/usr.
* gccnewlib/base-g77.add, gccnewlib/base-gcc.add,
gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add,
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add:
* gccnewlib/Makefile.am: Remove h8300-rtemscoff.
* binutils/Makefile.am: Remove h8300-rtemscoff.
* autotools/automake.add: Update to automake-1.9.6.
* brp-rtems-strip.in: New.
* brp-rtems-compress.in: New.
* binutils/binutils.add: Reflect using brp-rtems*.
* gccnewlib/gccnewlib.add: Reflect using brp-rtems*.
* binutils/binutils.add: Take out -D_FORTIFY_SOURCE from CFLAGS
to prevent fortify from rendering ar unusable.
* binutils/mkspec.in, gccnewlib/mkspec.in, gdb/mkspec.in:
Use ',' as sed pattern delimiter.
* autotools/automake.add: Add %{?dist}.
* autotools/autoconf.add: Add %{?dist}.
Replace Copyright: by Licence:.
* gccnewlib/gccnewlib.add: Remove Epoch.
* binutils/base-binutils.add, gccnewlib/base-g77.add,
gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add,
gdb/base-gdb.add: install-info --info-dir=.
* gccnewlib/mkspec.in: Correct patch handling magic.
* gccnewlib/gccnewlib.add: Reflect changes to mkspec.in.
Use --with/--without, rework logic for building optional languages.
* gccnewlib/header.add: Document --with/--without.
* gccnewlib/Makefile.am: Add h8300-rtemscoff*.
* gccnewlib/gccnewlib.add: Let building gnat require gcc.
Allow building arm-rtems*-gnat.
* gccnewlib/gccnewlib.add: Further clean up of tools not supported
by individual targets. Add %build_libgcj.
* gccnewlib/target-gcc.add: Remove dep to base-gcc.
* gccnewlib/gccnewlib.add: Suppress building tools not supported by
avr, h8300 and mips.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc.
%infodir/dir handling changes.
* rtemsdoc/rtemsdoc.add: Use BuildRequires instead of BuildPreReq
(rpm anachronism).
* gdb/base-gdb.add, gdb/gdb.add: Misc. %infodir/dir handling
changes.
gccnewlib/base-gnat.add: Misc. %infodir/dir handling changes.
* common/common.add.in: Use FC compliant BuildRoot.
* gccnewlib/gccnewlib.add: Remove gnatgcc hacks.
Misc %infodir/dir handling changes.
* gccnewlib.add: Remove gnatgcc hacks.
* target-c++.add, target-g77.add, target-gcj.add,
target-gfortran.add, target-gnat.add, target-objc.add:
Requires: %{rpmprefix}%{gcc_target}-gcc = %{version}-%{release}.
* binutils/base-binutils.add, binutils/binutils.add:
* configure.ac: Reflect changes to autotools/*.
* autotools/Makefile.am: Update.
* autotools/automake-rtems.spec.in, autotools/autoconf-rtems.spec.in:
Remove.
* autotools/automake.add, autotools/autoconf.add,
autotools/header.add: New.
* autotools/Makefile.am: Streamline specs generation with other
tools.
* gccnewlib/gccnewlib.add: Don't build mips-gcj. Further gnat
cleanup.
* rtemsdoc/supplement.add.in, rtemsdoc/templ.add.in: Misc. info
fixes.
* gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/target-gnat.add: Abandon Gnat for gcc < 4.0
* gccnewlib/base-gfortran.add: Fix broken install-info.
* gccnewlib/base-gnat.add, gccnewlib/target-gnat.add: Adaptations
to gcc-4.0.0. Install infos using FC conventions.
autotools/autoconf-rtems.spec.in: Remove rpm anachronisms.
* binutils/binutils.add: Install infos using FC conventions.
* binutils/base-binutils.add: Install infos using FC conventions.
* gdb/base-gdb.add: Install infos using FC conventions.
* gccnewlib/base-gcc.add: Install infos using FC conventions.
* gccnewlib/base-gcj.add: Install infos using FC conventions.
Various minor fixes.
* gccnewlib/base-gfortran.add: Install infos using FC conventions.
* gccnewlib/target-gcj.add: Various minor fixes.
