path: root/scripts (follow)
* 2004-05-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-242-0/+10
| | | | | * gcc3newlib/gccnewlib.add: gcc 3.4.0 is broken for embedded SPARC and Ada. Until we can fix it, it is disabled.
* 2004-05-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-242-1/+5
| | | | * gcc3newlib/target-gnat.add: Fix path to gnat1.
* 2004-05-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-05-184-5/+13
| | | | | | | * binutils/Makefile.am: Add sh-rtemscoff. Remove sh-rtemself. * binutils/binutils.add: BuildRequires flex. * autotools/automake-rtems.spec.in: Automake 1.8.5.
* 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-292-6/+12
| | | | | * gcc3newlib/gccnewlib.add: Another attempt to make *info.gz handling more robust.
* 2004-04-26 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-262-3/+7
| | | | * autotools/automake-rtems.spec.in: Upgrade to 1.8.4.
* 2004-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-279-87/+101
| | | | | | | * Index: base-g77.add, base-gcc.add, base-gcj.add, base-gnat.add, gccnewlib.add, target-c++.add, target-gcc.add, target-gcj.add: Apply _infodir, _mandir. Gzip man pages. Reflect gcc having fixed gccinstall.info.
* 2004-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-274-35/+48
| | | | | | | | * binutils/base-binutils.add: Apply _infodir. Don't install libiberty. Misc. cleanups. * binutils/binutils.add: Apply _infodir, _mandir. Don't install libiberty. Gzip man pages. Misc. cleanups. * binutils/target-binutils.add: Apply _mandir.
* 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-252-3/+7
| | | | * autotools/automake-rtems.spec.in: Upgrade to 1.8.3.
* 2004-03-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-186-34/+56
| | | | | | | | * gcc3newlib/gccnewlib.add: Disable gnats. Further preparations for gcc-3.4.0 * gcc3newlib/base-gcc.add, gcc3newlib/target-gnat.add, gcc3newlib/base-gcj.add, gcc3newlib/target-gcj.add: Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-184-9/+20
| | | | | | * gcc3newlib/base-gcc.add, gcc3newlib/target-g77.add, gcc3newlib/target-objc.add: Preps for gcc-3.4.0. Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-173-6/+17
| | | | | * gcc3newlib/target-gcc.add, gcc3newlib/target-c++.add: Reflect changes to gcc3newlib/gccnewlib.add.
* 2004-03-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-172-6/+26
| | | | | * gcc3newlib/gccnewlib.add: Preps. for gcc-3.4.0. Add %gcclib, %gccexec.
* 2004-03-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-03-152-11/+11
| | | | * binutils/base-binutils.add: Preparations for binutils-2.15.
* 2004-02-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-242-8/+8
| | | | | PR 580/tools * setup.def: Fix setup.def to match current reality.
* 2004-02-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-233-0/+11
| | | | | * gdb/base-gdb.add: Add annotate.info. * gdb/gdb.add: Remove info/dir.
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-203-3/+5
| | | | * Makefile.am, gdb/Makefile.am: Cosmetics.
* 2004-02-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-193-4/+16
| | | | * setup.def, gdb/gdb.add: gdb 6.0 RPMs built.
* 2004-02-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-191-3/+7
| | | | * ChangeLog: Replace RTEMS user account with Joel.
* 2004-02-17 RTEMSJoel Sherrill2004-02-174-12/+23
| | | | | * setup.def, gdb/base-gdb.add, gdb/gdb.add: Building a gcc 3.2.3 i960 gcc and updating gdb to 5.3.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-124-22/+4
| | | | * configure.ac, setup, setup.def: Remove now unused vars.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-1219-639/+13
| | | | | | | | | | | * mkgccnewlibspec.in, gccnewlib/.cvsignore, gccnewlib/HISTORY, gccnewlib/Makefile.am, gccnewlib/README, gccnewlib/base-chill.add, gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/gccnewlib.add, gccnewlib/header.add, gccnewlib/target-chill.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-objc.add: Remove (Obsolete). * configure.ac, Makefile.am: Reflect changes above.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-5/+14
| | | | | * gcc3newlib/gcc3newlib.add: Remove info/dir. Cosmetics.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-122-3/+9
| | | | | | * setup.def: Adapt to what Joel already ships - gcc3_version=3.3.2, gcc3_patch_version=20031216, gcc3newlib_rpm_release=3
* 2004-02-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-1011-90/+46
| | | | | | | | | | | | | | | | * configure.ac: Remove rtemsdoc/mkspec. Add RTEMS_RPM_RELEASE. * rtemsdoc/.cvsignore: Reformat. * Makefile.am: Reformat. Add RTEMS_RPM_RELEASE support to rtems-source.add, Use rtems_source_spec_DEPS instead of rtems_source_spec_DEPENDENCIES (Conflicts with automake internals). * rtems/rtems-source.add: Add RTEMS_RPM_RELEASE. * rtemsdoc/mkspec.in: Remove. * rtemsdoc/Makefile.am: Reworked. * rtemsdoc/header.add: Update Copyright notice. * rtemsdoc/rtemsdoc.add: Add RTEMS_RPM_RELEASE. Add %{rpmgroup}. Remove bzip-ing *.ps. * rtemsdoc/supplement.add.in: Add %{rpmgroup}. * rtemsdoc/templ.add.in: Add %{rpmgroup}.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-092-4/+13
| | | | * rtems/rtems-source.add: Require automake-1.8.2, autoconf-2.59.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-094-2/+44
| | | | | | | * rtems/rtems-source.add: New. * Makefile.am: Add rtems/rtems-source.spec handling. * configure.ac: AC_SUBST(RTEMS_VERSION,[_RTEMS_VERSION]). * common/common.add.in: Use www.rtems.com as Vendor.
* 2004-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-042-19/+6
| | | | * configure.ac: Use RTEMS_ENABLE_RPMPREFIX.
* 2004-01-28 RTEMSJoel Sherrill2004-01-288-29/+26
| | | | | | | * buildall.in, buildalltar.in, binutils/Makefile.am, cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am: Attempt to convert all c4x-rtems references to tic4x-rtems. Left the rtems documentation alone.
* 2004-01-28 RTEMSJoel Sherrill2004-01-285-7/+14
| | | | | | | * configure.ac: Enable OS versioning by default for 4.7 branch. * setup.def: Update binutils RPM version and build new gcc 3.2.3 RPMs. * autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in: Update for new tool spin.
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-132-2/+6
| | | | * scripts/automake.spec.in: 1.8.2.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-122-2/+12
| | | | | | * scripts/automake.spec.in: 1.8.1. Add Patch0 automake-1.8.1-rtems-20040112-1.diff. Add defattr, URL:-tag.
* 2004-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-082-2/+7
| | | | | * setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031216 gcc patch (RPM revision 4.7-2).
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-0711-30/+13
| | | | | | | | * buildall.in, buildalltar.in, binutils/Makefile.am, cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore, rtemsdoc/Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-162-3/+8
| | | | | * setup.def: Update gcc/newlib for 4.7 series to 3.3.2 with 20031022 gcc patch (RPM revision 4.7-1).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1112-63/+53
| | | | | | | | | | | | | | * Makefile.am: Cosmetics. * autotools/Makefile.am: Cosmetics. * autotools/autoconf-rtems.spec.in: 2.59. * autotools/automake-rtems.spec.in: 1.8, Require autoconf-2.59. * binutils/Makefile.am: Cosmetics. * cpukit/Makefile.am: Cosmetics. * gcc3newlib/Makefile.am: Cosmetics. * gccnewlib/Makefile.am: Cosmetics. * gdb/Makefile.am: Cosmetics. * rtems/Makefile.am: Cosmetics. * rtemsdoc/Makefile.am: Cosmetics.
* 2003-11-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-173-1/+49
| | | | | | * gcc3newlib/gccnewlib.add: Add hacks to make gnatlib buildable. * gcc3newlib/base-gnat.add: Add info files.
* 2003-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-302-2/+8
| | | | | * gcc3newlib/gccnewlib.add: Make not building gnat and gcj the default for gcc-3.3.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-233-1/+9
| | | | | * binutils/Makefile.am: Add tic4x. * binutils/mkspec.in: Remove duplicate rpmgroup.
* 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-223-0/+16
| | | | | | * gcc3newlib/Makefile.am: Add tic4x. * gcc3newlib/gccnewlib.add: Don't install install-tools for gcc >= 3.3.
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-223-5/+10
| | | | | * configure.ac, setup.def: Update to binutils 2.14 adn gcc/newlib to 3.2.3 with 20030826 gcc patch.
* 2003-10-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-075-51/+67
| | | | | | | | * cpukit/target-cpukit.add: New. * cpukit/Makefile.am: Reflect having added target-cpukit.add. Acknowledge osversion. * cpukit/mkspec.in: Acknowledge osversion and rpmgroup. * cpukit/rtems-cpukit.add: Reflect new RTEMS spec conventions.
* 2003-10-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-072-2/+6
| | | | * autotools/automake-rtems.spec.in: Automake-1.7.8.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2611-36/+17
| | | | | | | * buildall.in, buildalltar.in, binutils/Makefile.am, cpukit/Makefile.am, gcc3newlib/Makefile.am, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore, rtemsdoc/Makefile.am: Obsoleting HP PA-RISC port.
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-242-2/+6
| | | | * autotools/automake-rtems.spec.in: Automake-1.7.7.
* 2003-09-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-184-6/+14
| | | | | | * gcc3newlib/gccnewlib.add: Fix duplicate removal of c++filt. * gcc3newlib/base-gcj.add: Add fastjar.info, jar.1, grepjar.1. * setup.def: gcc3newlib_rpm_release=4.
* 2003-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-0418-102/+125
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * binutils/base-binutils.add: Add osversion support. * binutils/binutils.add: Add osversion support. %setup -n %{name}-%{version}. Don't remove c++filt. * binutils/target-binutils.add: Add osversion support. Pickup c++filt. * gcc3newlib/base-g77.add: Add osversion support. * gcc3newlib/base-gcc.add: Add osversion support. * gcc3newlib/base-gcj.add: Add osversion support. * gcc3newlib/base-gnat.add: Add osversion support. * gcc3newlib/gccnewlib.add: Add osversion support. Remove c++filt, %setup -n -n %{name}-%{version}. * gcc3newlib/target-c++.add: Add osversion support. Don't pickup c++filt. * gcc3newlib/target-g77.add: Add osversion support. * gcc3newlib/target-gcc.add: Add osversion support. * gcc3newlib/target-gcj.add: Add osversion support. * gcc3newlib/target-gnat.add: Add osversion support. * gccnewlib/gccnewlib.add: %setup -n %{name}-%{version}. * gdb/base-gdb.add: Add osversion support, rpmgroup, rpmprefix, gdb_version, gdb_target. * gdb/target-gdb.add: Ditto. * gdb/gdb.add: Ditto. %setup -n -n %{name}-%{version}.
* 2003-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-043-4/+9
| | | | | * binutils/Makefile.am: Fix osversion support for sh-rtemself. * gcc3newlib/Makefile.am: Fix osversion support for sh-rtemself.
* 2003-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-048-119/+145
| | | | | | | | | | | * configure.ac: Add --enable-osversions (OS-versioned RPMS support). * binutils/Makefile.am: Add osversion support. * binutils/mkspec.in: Add osversion support. * gcc3newlib/Makefile.am: Add osversion support. * gcc3newlib/mkspec.in: Add osversion support. * gdb/Makefile.am: Add osversion support. * gdb/mkspec.in: Add osversion support. Add rpmprefix, rpmgroup.
* 2003-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-0230-146/+218
| | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, autotools/autoconf-rtems.spec.in, autotools/automake-rtems.spec.in, binutils/Makefile.am, binutils/base-binutils.add, binutils/binutils.add, binutils/mkspec.in, binutils/target-binutils.add, common/common.add.in, cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/base-g77.add, gcc3newlib/base-gcc.add, gcc3newlib/base-gcj.add, gcc3newlib/base-gnat.add, gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, gcc3newlib/target-c++.add, gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add, gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add, gcc3newlib/target-objc.add, gccnewlib/Makefile.am, gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/Makefile.am: Merger from rtems-4-6-branch. * common/common.am: New.
