* .cvsignore: Add buildalltar.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
* mkgdbspec.in: Make list of simulators very complete.
* setup.def: Update versions.
* setup.def, binutils.add, gccnewlib.add: Updated to build
binutils 2.11.2 (rtems patch 20010622), gcc 2.95.3 (rtems
patch a20010622), and newlib 1.9.0 (rtems patch 10020622).
* configure.in: Remove AC_EXEEXT, treat .exe manually.
* gccnewlib/base-gcc.add: Remove cpp.
* gccnewlib/gccnewlib.add: mv cpp $target_alias-cpp, update
copyright.
* setup.def: Modified the binutils version to 2.11 and
RPM revision 3 to reflect experimentation with new binutils release.
* binutils/Makefile.am: Added a29k-rtems.
* binutils/binutils.add: Switch to .bz2 extension to reflect
real way code is compressed on distribution sites now.
* setup.def: Updated version numbers and patches for binutils
and gdb. binutils was to get correct patch in field. gdb
was to add mipstx39-rtems configurery support.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* gccnewlib/gccnewlib.add: Fix typo in URL.
* configure.in: Adapt m4-quoting to autoconf-2.49b, use $host
instead of $target to setup RPM_CPU, move chmod 755 buildall to
AC_OUTPUT's extra-cmds.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* setup.def: Updating version numbers for gcc/newlib RPM release 10.
* setup.def: Updated gcc and newlib patches and bumped RPM revision.
Patches primarily add or16/or32 basic support to newlib and
i386 multilib improvements to gcc from Ralf Corsepius.
fixes:
+ the h8300-rtems and hppa1.1-rtems configure.in stanzas
+ config/rs6000/rtems.h start and end file specs
Ralf's patch to split the .spec files into multiple ".add" parts.
that contains:
* Removes MKLIB
handling)
for RTEMS toolkit.
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
by all targets and one or more target specific RPMs. This significantly
reduces the conflicts between the RPMs whether installing one or multiple
targets.
packages.
Cygwin support to the RPM scripts. The patch from David did not
apply cleanly and Joel ended up making all the modifications
plus some it should have included for consistency by hand. His comments:
I've included a diff against the last (19991203) snapshot RPM scripts that
adds what I think is required for Cygwin support. Basically all this boils
down to is adding EXE extension support. I've added the AC_EXEEXT rule to
conifgure.in (requires a valid 'cc' to work - this is not available in the
standard Cygwin distro). Each of the *.spec.in have @exe_ext@ includes in
them for each program that results in an EXE. The only odity here is that
the chill driver program is a shell script and thus does not require .exe to
be added... The mk*.in have all been updated to process the new exe_ext
rule.
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
and powerpc targets.
