* configure.ac: Fix typo to allow custom RPM_SPECSdirs.
* setup.def: Bumped the gdb_patch_version to account for a configuration
problem on psim where it could not be enabled for powerpc-RTEMS.
* gdb/Makefile.am: Add i386-RTEMS and powerpc-RTEMS targets.
* mkbinutilsspec.in: Guard sed-pattern against autoconf.
* mkgccnewlibspec.in: Guard sed-pattern against autoconf, remove
Target_alias.
* mkgdbspec.in: Guard sed-pattern against autoconf.
* mkbspspec.in: Guard sed-pattern against autoconf.
* configure.ac: Rework check for RPM_SPECSdir.
* autotools/automake-rtems.spec: Update to automake-1.5.
* configure.in: Remove.
* gdb/Makefile.am, gccnewlib/Makefile.am, binutils/Makefile.am:
Initially setup CLEANFILES using = instead of += to make
automake-1.5 happy.
* setup.def, gccnewlib/gccnewlib.add, gccnewlib/target-gcc.add:
Revert changes because of gcc 2.5.x/3.0 transition and continue
to support gcc 2.95.x as primary version.
* mkgccnewlibspec.in,
Use Target_alias not target_alias to avoid conflicts with new autoconf.
* setup.def: Changed version numbers in attempt at building gcc 3.0.1.
Only sparc and arm built for C/C++ OK. :(
* gccnewlib/base-gcc.add: Modifications to reflect files not in gcc 3.x.
* gccnewlib/gccnewlib.add: gcc 3.x does not have "everything in the name"
* target-gcc.add: Modifications to reflect files not in gcc 3.1
* autotools/.cvsignore: New file.
* autotools/Makefile.am, autotools/autoconf-rtems.spec,
autotools/automake-rtems.spec: New.
* configure.in, Makefile.am: Add autotools/.
* .cvsignore: Add buildalltar.
* buildalltar.in: New file.
* configure.in, Makefile.am: Modified to reflect addition of file.
* mkgdbspec.in: Make list of simulators very complete.
* setup.def: Update versions.
* setup.def, binutils.add, gccnewlib.add: Updated to build
binutils 2.11.2 (rtems patch 20010622), gcc 2.95.3 (rtems
patch a20010622), and newlib 1.9.0 (rtems patch 10020622).
* configure.in: Remove AC_EXEEXT, treat .exe manually.
* gccnewlib/base-gcc.add: Remove cpp.
* gccnewlib/gccnewlib.add: mv cpp $target_alias-cpp, update
copyright.
* setup.def: Modified the binutils version to 2.11 and
RPM revision 3 to reflect experimentation with new binutils release.
* binutils/Makefile.am: Added a29k-rtems.
* binutils/binutils.add: Switch to .bz2 extension to reflect
real way code is compressed on distribution sites now.
* setup.def: Updated version numbers and patches for binutils
and gdb. binutils was to get correct patch in field. gdb
was to add mipstx39-rtems configurery support.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* setup.def, binutils/HISTORY, gccnewlib/HISTORY: Updated
binutils HISTORY to reflect new revision. Updated gcc to fix
i960 C++ problem. Updated newlib to move to newlib 1.9.0.
* gccnewlib/gccnewlib.add: Fix typo in URL.
* configure.in: Adapt m4-quoting to autoconf-2.49b, use $host
instead of $target to setup RPM_CPU, move chmod 755 buildall to
AC_OUTPUT's extra-cmds.
* buildall.in, mkgdbspec.in, setup.def, binutils/Makefile.am,
gccnewlib/HISTORY, gccnewlib/Makefile.am, gdb/Makefile.am:
Added mips-rtems, updated to include new patches and
gcc 2.95.2/newlib 1.8.2 revision 11 RPM.
* configure.in: Remove trailing '/'s from setting up RPM_SPECdir.
* setup.def: Updating version numbers for gcc/newlib RPM release 10.
* setup.def: Updated gcc and newlib patches and bumped RPM revision.
Patches primarily add or16/or32 basic support to newlib and
i386 multilib improvements to gcc from Ralf Corsepius.
fixes:
+ the h8300-rtems and hppa1.1-rtems configure.in stanzas
+ config/rs6000/rtems.h start and end file specs
Ralf's patch to split the .spec files into multiple ".add" parts.
that contains:
* Removes MKLIB
handling)
for RTEMS toolkit.
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
