* setup.def, gdb/gdb.add: Add gdb_suffix.
* gcc3newlib/HISTORY, gcc3newlib/Makefile.am, gcc3newlib/README,
gcc3newlib/base-g77.add, gcc3newlib/base-gcc.add,
gcc3newlib/base-gcj.add, gcc3newlib/base-gnat.add,
gcc3newlib/gccnewlib.add, gcc3newlib/header.add,
gcc3newlib/mkspec.in, gcc3newlib/target-c++.add,
gcc3newlib/target-g77.add, gcc3newlib/target-gcc.add,
gcc3newlib/target-gcj.add, gcc3newlib/target-gnat.add,
gcc3newlib/target-objc.add: Remove.
* gccnewlib/mkspec.in: Use gccnewlib/ instead of gcc3newlib/.
* Makefile.am, configure.ac: Use gccnewlib/ instead of gcc3newlib/.
* README.cdn-X: Minor updates.
* gccnewlib/.cvsignore, gccnewlib/Makefile.am,
gccnewlib/README, gccnewlib/base-g77.add,
gccnewlib/base-gcc.add, gccnewlib/base-gcj.add,
gccnewlib/base-gnat.add, gccnewlib/gccnewlib.add,
gccnewlib/header.add, gccnewlib/mkspec.in,
gccnewlib/target-c++.add, gccnewlib/target-g77.add,
gccnewlib/target-gcc.add, gccnewlib/target-gcj.add,
gccnewlib/target-gnat.add, gccnewlib/target-objc.add:
New.
* cpukit/rtems-cpukit.add, gdb/gdb.add:
Fix my email address, cosmetics.
* setup, setup.def, gcc3newlib/mkspec.in:
s/gcc3newlib_rpm_release/gccnewlib_rpm_release/g.
* setup: Fixup messages.
* binutils/target-binutils.add, cpukit/rtems-cpukit.add,
gcc3newlib/gccnewlib.add, gdb/gdb.add, rtemsdoc/rtemsdoc.add:
Remove Autoreqprov-tag.
* gcc3newlib/gccnewlib.add: Default to not building gcj for all gcc
versions. Cleanup comments.
* configure.ac, setup, setup.def, gcc3newlib/mkspec.in:
Use newlib_* instead of gcc3newlib_* for setup.* values.
Use gcc_* instead of gcc3_* for setup.* values.
* binutils/binutils.add, gdb/gdb.add: Sync %setup with gcc/gcc.add
for consistency.
* binutils/binutils.add, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Apply patches in tool subdirs.
* binutils/binutils.add, binutils/mkspec.in:
Eliminate @PATCH2@.
* gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in:
Eliminate @PATCH2@, @PATCH4@.
* gdb/gdb.add, gdb/mkspec.in:
Eliminate @PATCH2@.
gdb/gdb.add: Add support for rpmbuild --with sources.
* gdb/Makefile.am: Add avr, mips64.
Cosmetics.
* gdb/base-gdb.add: Reflect gdb-6.3 not shipping mmalloc.info*.
* gdb/target-gdb.add: Add support for gcc-6.3's gdbtui.
* gdb/mkspec.in: Add PATCH-magic.
Add gdb_suffix.
* binutils/binutils.add, binutils/mkspec.in, setup.def:
Add binutils_suffix.
* binutils/target-binutils.add: Preparations for binutils-2.16.
* gcc3newlib/gccnewlib.add, gcc3newlib/mkspec.in, setup.def:
Add gcc_suffix. Add newlib_suffix.
* autotools/automake-rtems.spec.in: automake-1.9.5.
* gcc3newlib/Makefile.am: Remove sh-rtemself. Add sh-rtemscoff.
* gcc3newlib/gccnewlib.add: Disable Ada (Stil broken with GCC-4.0.0).
* gcc3newlib/gccnewlib.add: Change my email address.
Add tic4x-*.
* autotools/automake-rtems.spec.in: automake-1.9.4.
* setup.def: Include PowerPC patch to make C++ global constructors work
-- gcc 3.3.5/newlib-1.12.0 revision 2.
* setup.def: Update gcc to 3.3.5 and binutils to 2.15.
* autotools/autoconf-rtems.spec.in: Temporarily do not include
some of the documentation since it causes the RPM build to fail.
* binutils/Makefile.am, gcc3newlib/Makefile.am: Add mips64-rtems.
* buildall.in, buildalltar.in, binutils/Makefile.am,
cpukit/Makefile.am, gcc3newlib/Makefile.am, gcc3newlib/gccnewlib.add,
gdb/Makefile.am, rtems/Makefile.am, rtemsdoc/.cvsignore,
rtemsdoc/Makefile.am: i960 obsoleted.
* binutils/binutils.add: Rename package from binutils-collection to
binutils. Cleanups.
* binutils/target-binutils.add: Reflect changes above.
* binutils/Makefile.am: Add avr. Reflect changes above.
* autotools/autoconf-rtems.spec.in: Cleanup for chroot'ed builds.
* autotools/automake-rtems.spec.in: automake-1.9.2.
* gcc3newlib/Makefile.am: Add avr-rtems*gcc.
* gcc3newlib/gccnewlib.add: Disable c++ for avr.
* autotools/automake.spec.in: automake-1.9.
* gcc3newlib/gccnewlib.add: gcc 3.4.0 is broken for embedded SPARC and
Ada. Until we can fix it, it is disabled.
