* ChangeLog: Removed duplicate entry.
* setup.def: Updated patch to fix m68k cut and paste bug which turned
a tab into spaces in a Makefile fragment.
* gcc3newlib/gccnewlib.add: If building gnat for the mips, the library
must be built with a -G0 option.
* setup.def, gcc3newlib/gccnewlib.add: Updated to gcc 3.2.1 RPM revision
2 which enabled the mips-rtems gnat using gcc 3.2.1 patch 20021129.
* setup.def: Updated to gcc-3.2.1.
* setup.def: Updated to gcc-3.2 and newlib1.1.0 RPM version 6.
* gcc3newlib/gccnewlib.add: Reenabled i386-rtems gnat.
Remove *.la's to make rpm-4.1/RH-8.0 happy.
Remove libiberty.a to make rpm-4.1/RH-8.0 happy.
Change gcc/version.c to reflect us having patched gcc.
* binutils/binutils.add: Add BuildPreReq: /sbin/install-info.
Disable nls.
Apply gzip -9qf to compress *infos and *mans.
Apply /sbin/install-info.
Remove *c++-filt.
* binutils/base-binutils.add: Add PreReq: /sbin/install-info.
Package as.info-*.gz.
* binutils/target-binutils.add:
Package man1/*.1*.
* autotool/autoconf-rtems.spec.in: Fix @prefix@.
* setup.def: Switched to binutils 2.13.1
* binutils/Makefile.am: Remove a29k-rtems.
* setup.def, gcc3newlib/gccnewlib.add: Patch includes updates
which were patch changes for -3 and -4 RPM revisions. Disabled
build of gnat for i386-rtems as it failed to build.
* gcc3newlib/gccnewlib.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.)
* binutils/binutils.add: Remove %{target} != %{build} comment
(RH-8.0/rpm-4.1 bogusly expands the macros and chokes.).
Comment out CONFIGURE_ARGS (RH-8.0/rpm-4.1 is broken wrt. _build_os
and _target_os)
* gcc3newlib/base-gcc.add: Add gccint*infos.
* gcc3newlib/base-gcj.add: Add gcj*infos.
Mark manpages as %doc and pickup the gzipped versions.
* autotools/automake-rtems.spec.in: Fix my address. Set up PATH
before running configure (Prep. for automake >= 1.7).
* autotools/autoconf-rtems.spec.in: New.
Remove Provides: autoconf (Conflicts with RH-8.0).
* autotools/autoconf-rtems.spec: Remove.
Remove Provides: automake (Conflicts with RH-8.0).
* gcc3newlib/Makefile.am: Remove references to mkgcc3newlibspec.
* Makefile.am: Ditto.
* configure.ac: Add autotools/autoconf-rtems.spec.in.
* setup.def: Update gcc 3.2 pathc to includ epatch for gcc PR8314.
* gcc3newlib/gccnewlib.add: Don't build mips/gnat as we do not
currently include the patch referenced in PR8344.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* gcc3newlib/base-gcj.add, gcc3newlib/gccnewlib.add,
gcc3newlib/target-gcj.add: First attempt at enabling Java support.
* setup.def, gcc3newlib/gccnewlib.add: Updated the tools for
gcc 3.2 and Ada.
* gcc3newlib/gccnewlib.add: Re-add i386-rtems Ada.
Add %_gnat and --define 'gnat [0|1]' support.
Enable gnat for gcc-3.2/Disable for gcc-3.1.
Add hacks to build gnatlib.
Re-activate commented out fragments for old gcc versions.
Add @target_alias@-gnatgcc.
* setup.def: New gcc 3.1 RPMs (-7).
* gcc3newlib/gccnewlib.add: i386-rtems doesn't build Ada.
* gcc3newlib/Makefile.am: Remove c_only remnants.
* gcc3newlib/gccnewlib.add: Reflect gcc-3.2 putting c++
headers into c++ instead of g++.
* gcc3newlib/target-c++.add: Ditto.
* ChangeLog: Fix bogus entry.
* gcc3newlib/base-gnat.add: Don't use %{%prefix}/bin/gnat*.
* gcc3newlib/Makefile.am: Use mkspec for c4x.
* gcc3newlib/gccnewlib.add: Rework processing of %if %build_XXX.
Rework handing Ada.
Don't put adalib and adainclude into files.gcc.
* gcc3newlib/target-gnat.add: Add adalib.
Add adainclude.
* gcc3newlib/base-gnat.add: Use -n rtems-base-gnat.
* gcc3newlib/.cvsignore: Add mkspec.
* mkgcc3newlibspec.in: Remove
* gcc3newlib/mkspec.in: New.
* gcc3newlib/gccnewlib.add: Add build_XXX defines.
Add preliminary gnat support.
* gcc3newlib/base-g77.add: Add build_g77.
* gcc3newlib/base-gcj.add: Add build_gcj.
* gcc3newlib/base-gnat.add: New.
* gcc3newlib/target-c++.add: Add build_cxx.
* gcc3newlib/target-g77.add: Add build_g77.
* gcc3newlib/target-gcj.add: Add build_gcj.
* gcc3newlib/target-objc.add: Add build_objc.
* gcc3newlib/target-gnat.add: New.
* gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec.
* setup.def: Increment release for gcc3newlib.
* gcc3newlib/gccnewlib.add: Do not put cc1plus into gcc-rpm.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* setup.def: Updating gcc3/newlib patches and tool versions. The
focus of this round of patches was ot eliminate header file name
conflicts between RTEMS and newlib.
* setup.def: Updated to gcc3.1/newlib 1.10.0 RPM revision 5 with
the gcc3 patch 20020730a and newlib 1.10.0 patch 20020726.
* autotools/automake-rtems.spec.in: Automake-1.6.3.
* cpukit/.cvsignore: Add mkspec. Remove rtems.spec.
* configure.ac: Use AC_CONFIG_FILES(script, chmod +x script)
to generate mk*spec scripts.
* mkbspspec.in: Use ',' as pattern delimiter in sed expression
for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed
expression for $rpm_build_root.
* cpukit/mkspec.in: Cosmetical changes.
* ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to
Joel.
* cpukit/Makefile.am: New.
* cpukit/mkspec.in: New.
* cpukit/rtems-cpukit.spec.in: New.
* cpukit/.cvsignore: New.
* configure.ac: Add cpukit.
Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit).
* Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup
RTEMS_VERSION).
* setup.def: Use %{_tmppath} as default for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression
* mkgccnewlibspec.in: Use ',' as pattern delimiter in sed
* mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed
* mkgdbspec.in: Use ',' as pattern delimiter in sed expression for
$rpm_build_root.
* binutils/Makefile.am: Add or32-rtems-binutils.
* setup.def: Updated newlib patch to get sh and hppa crt0 mods.
* setup.def: Update gcc3 RPMs for new patches.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* mkgdbspec.in, setup.def, gcc3newlib/gccnewlib.add, gdb/gdb.add:
Updated to gcc 3.1 and gdb 5.2.
* setup.def: Updated to binutils 2.12.1.
* rtems/Makefile.am: Remove m68k-rtemself references.
* mkgcc3newlibspec.in: Remove SETUP (bogus).
* gcc3newlib/target-c++.add: New.
* gcc3newlib/Makefile.am: Add target-c++.add.
* gcc3newlib/base-g77.add: Adapt to gcc-3.1.
Reflect having split out c++. Various minor fixes.
* gcc3newlib/base-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Ditto.
* gcc3newlib/target-gcc.add: Ditto.
* gcc3newlib/gccnewlib.add: Add gcc_update --touch to fix
timestamps.
* .cvsignore: Added files added by automake 1.6.1.
* setup.def: New shot at gcc 3.0.4 RPMs.
* binutils/Makefile.am, gdb/Makefile.am, rtems/Makefile.am:
Deleted m68k-rtemself.
* gcc3newlib/gccnewlib.add: Commented out host/target OS check.
* autotools/automake-rtems.spec.in: Update to automake-1.6.1.
Use *.tar.bz2.
* mkbinutilspec.in: Fix PATCH2.
* gcc3newlib/gccnewlib.add: Add -Bgcc/ when collecting multilibs.
* gcc3newlib/gccnewlib.spec.in: Removed from CVS.
* mkbinutilspec.in: Add support for empty patch-version (no patch).
* mkgcc3newlibspec.in: Ditto.
* setup: Fix gcc3*_versions handling.
* setup.def: binutils_patch_version=.
* binutils/binutils.add: Reflect changes to mkbinutilspec.in,
Use "%{_target_os}" != "%{_build_os}" to detect cross-building.
* binutils/target-binutils.add: Comment out c++filt.
* gcc3newlib/base-gcc.add: Remove duplicate libm.info.
* gcc3newlib/gccnewlib.add: Reflect changes to mkgcc3newlibspec.in.
Comment out gcc-2.95.x hacks.
Remove *.la from installed files.
* gcc3newlib/gccnewlib_c_only.spec.in: Remove.
* buildall.in: Correct logic for detecting 0 RTEMS RPMS installed.
* .cvsignore: Added mkgcc3newlib.
