path: root/scripts (follow)
* Updated to new patch.Joel Sherrill2000-07-112-4/+12
* Using RPM names for versions now.Joel Sherrill2000-06-291-6/+6
* Corrected.Joel Sherrill2000-06-291-7/+3
* New file.Joel Sherrill2000-06-293-0/+85
* Switch to gcc patch 20000629 and revision level 8. This patchJoel Sherrill2000-06-291-2/+2
| | | | | | fixes: + the h8300-rtems and hppa1.1-rtems configure.in stanzas + config/rs6000/rtems.h start and end file specs
* h8300-rtems now uses the correct command to generate the specs file.Joel Sherrill2000-06-291-1/+1
* Added initial h8300 support.Joel Sherrill2000-06-295-8/+26
* gdb 5.0 does not install readline so don't try to grab the info files.Joel Sherrill2000-06-291-1/+2
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1230-126/+902
* These files were added or deleted on the 4.5 branch as part ofJoel Sherrill2000-05-289-3283/+0
| | | | Ralf's patch to split the .spec files into multiple ".add" parts.
* Added on 4.5 branchJoel Sherrill2000-05-2816-0/+0
* Added on branch.Joel Sherrill2000-05-212-0/+1873
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-135-0/+29
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-1/+1
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to match his CygwinJoel Sherrill2000-02-082-2/+5
| | | | for RTEMS toolkit.
* Updated version numbers.Joel Sherrill2000-02-081-2/+2
* Patches rtems-rc-20000118-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-012-1/+6
| | | | | | | | | | | | | | | | | | | | | | | | | that contains: * The fix for the gen68360/network/Makefile.am * automatically set permissions to 755 to scripts/buildall and scripts-ada/buildall (I remembered a trick to achieve this :). * automake support for libbsp/* and libcpu/* (Attn: This part will finally break old-style configuration for all non-public cpus) NOTES: * This patch has only been tested for a random selection of BSPs (I haven't rebuilt all toolchains yet). * This patch is against rtem-cvs as of this morning (MET). To apply: patch -p1 <rtems-rc-20000118-5.diff cvs rm -f ./c/src/lib/libbsp/Makefile.in cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in cvs rm -f ./c/src/lib/libcpu/Makefile.in cvs add ./c/src/lib/libbsp/Makefile.am cvs add ./c/src/lib/libbsp/shmdr/Makefile.am cvs add ./c/src/lib/libcpu/Makefile.am ./bootstrap
* Changed versions of newlib patch.Joel Sherrill2000-01-311-2/+2
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-316-102/+176
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Updated versions.Joel Sherrill2000-01-311-2/+2
* Removed gnat and made final cleanup.Joel Sherrill2000-01-278-269/+50
* Patch rtems-rc-20000118-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-272-340/+0
| | | | | | | | | | | | | | | | | | | | that converts the a29k to automake. This patch contains * An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS, most code inside them seems to be empty stubs. One file even contains a function called mips_*** which might indicate that this part might contain mips code or the code the initial porter used as template for porting. Unfortunately, I don't know anything about the a29k so I can't comment on the details. * A dummy bsp_specs to libbsp/29k/portsw * An update to the automake files related to the a29k. Note: * This patch is completely untested, because I don't have a toolchain for it. * The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue hits again.
* Now binutils, gcc, and gdb build into a "base" package that is sharedJoel Sherrill2000-01-258-13/+40
| | | | | | by all targets and one or more target specific RPMs. This significantly reduces the conflicts between the RPMs whether installing one or multiple targets.
* Attempting to split binutils and gcc into base/shared and CPU specificJoel Sherrill2000-01-243-31/+71
| | | | packages.
* Patch from David Fiddes <D.J@fiddes.surfaid.org> which adds basicJoel Sherrill2000-01-2311-62/+74
| | | | | | | | | | | | | | | | Cygwin support to the RPM scripts. The patch from David did not apply cleanly and Joel ended up making all the modifications plus some it should have included for consistency by hand. His comments: I've included a diff against the last (19991203) snapshot RPM scripts that adds what I think is required for Cygwin support. Basically all this boils down to is adding EXE extension support. I've added the AC_EXEEXT rule to conifgure.in (requires a valid 'cc' to work - this is not available in the standard Cygwin distro). Each of the *.spec.in have @exe_ext@ includes in them for each program that results in an EXE. The only odity here is that the chill driver program is a shell script and thus does not require .exe to be added... The mk*.in have all been updated to process the new exe_ext rule.
* Updated versions.Joel Sherrill2000-01-141-6/+6
* Updated list of targets to build.Joel Sherrill2000-01-141-2/+1
* Uncommitted remains of a previous patch from Ralf CorsepiusJoel Sherrill1999-11-301-106/+0
| | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake.
* RTEMS RPM basically working.Joel Sherrill1999-11-225-20/+30
* Corrected to include extra arguments for simulators on sparcJoel Sherrill1999-11-181-1/+1
| | | | and powerpc targets.
* Corrected to remove references to non-existent subpackages.Joel Sherrill1999-11-181-2/+2
* Added code to set extra configure arguments for sparc and powerpc targetsJoel Sherrill1999-11-181-4/+19
| | | | | | | such that the simulator is enabled. Also corrected a typo which prevented the simulator files from being included in the file list.
* Added ";;" to correct syntactical error.Joel Sherrill1999-11-181-0/+1
* Patch rtems-rc-19991105-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-161-1/+6
| | | | | | | This is the gdb.spec.in fix patch: * install infos gzip-ed * add gdb to group rtems
* Removed.Joel Sherrill1999-11-051-249/+0
* Added this file as a way to build RPMs for CPUs that would onlyJoel Sherrill1999-11-051-0/+174
| | | | | successfully build C/C++ and not all of the other languages included in late model egcs/gcc releases.
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-044-47/+19
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Added first stab at mkgnatnewlib.Joel Sherrill1999-11-046-0/+692
* Fixed typo.Joel Sherrill1999-11-021-1/+1
* Clean up /opt/rtems in case junk is installed in the wrong place.Joel Sherrill1999-11-021-4/+4
| | | | This has been seen on some machine configurations.
* Latest version from Ralf Corsepius <corsepiu@faw.uni-ulm.de> whichJoel Sherrill1999-10-271-44/+103
| | | | splits gcc, gcj, chill, f77 and objc into separate rpms..
* Removing automatically generated files.Joel Sherrill1999-10-264-1088/+0
* Removed generated file.Joel Sherrill1999-10-261-1101/+0
* New versions for gcc and patch.Joel Sherrill1999-10-261-2/+2
* RegeneratedJoel Sherrill1999-10-266-27/+34
* Patch generated from scripts-19991025-0.tar.gz fromJoel Sherrill1999-10-2510-74/+143
| | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>: Most significant changes: * Names for rpms changed again * gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes c/c++/f77/objc), simultaneously built from a common *.spec. * small patches with major impact to gcc and newlib (Those fixes mentioned to Ian, ie. libobjc/libchill are built, multilibing works) * gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without major problems) * Buildroot removed from */*spec.in * New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages)
* Regnenerated following update from Ralf.Joel Sherrill1999-10-256-27/+34
* Merged scripts-19991022-0 changes from Ralf.Joel Sherrill1999-10-2510-122/+82
* Changed version number.Joel Sherrill1999-10-251-1/+1
* Now builds RPM without complete source. Each target is only 15K.Joel Sherrill1999-10-216-9/+59
