* custom/armulator.cfg: Corrected make-exe rule to pick up debug flags.
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* custom/mbx8xx.cfg: Add support for configuration parameters in NVRAM
* ChangeLog: File paths corrected.
* mvme167.cfg: Add specification of printk port, console port
and serial I/O mode. Arrange for the stripped executable to
be copied up the build tree.
* mbx8xx.cfg: Support for shared printk and no termios.
2000-08-10 John Cotton <john.cotton@nrc.ca>
* mbx8xx.cfg: Support added for dejagnu test harness.
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
that does the following:
Remove $(SED) and $(CP) from make/custom/*.cfg
Motivation:
* autoconf and automake presuppose sed and cp to be present.
* make/host.cfg.in already contains SED = sed hard-coded into it for
a long time.
* Elimination of make-variables
* Eliminate make/*.cfg files or at least reduce their complexity :)
Removed obsolete flags from new custom files.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
enabled now at configure time.
cpuopts.h.
to disabled.
problems at runtime.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
that removes setting unused variables WORKSPACE_MB and HEAPSPACE_MB.
find tools like packhex after installation.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
significant things:
and PowerPC
same code base.
significant things:
and PowerPC
same code base.
by gdb 5.0's i960 simulator) is enough to run hello world.
linkcmds updated, simio references removed, and switch to libchip for
serial ports from simio.
Added a MEMORY_MAP file to capture information about the various
addresses on this board.
In addition, many of the beta patches are now included.
Erwin Rol <erwin@muffin.org>.
that contains:
* Removes MKLIB
handling)
that contains:
The workarounds related to the issues with
ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg
(Which is basically broken)
patch -p1 < rtems-rc-20000118-6.diff
./bootstrap
Note:
* Though this patch is small, ./bootstrap is absolutely necessary.
* Now your CVS source tree is identical to my local CVS.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
is no way to build this target.
pc686.cfg was not present.
