path: root/make (follow)
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-134-0/+9
| | | | adds .cvsignore.
* Cleanup patch from Ralf Corsepius.Joel Sherrill2000-04-051-1/+1
* New file. Should support Cygwin as unix simulator port.Joel Sherrill2000-04-051-0/+65
* BSP now compiles and links with CAVSL board information. This includesJoel Sherrill2000-02-292-2/+2
| | | | | | | | | | linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included.
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-222-0/+71
* Fixed typos introduced in last modification. Spotted byJoel Sherrill2000-02-111-6/+6
| | | | Erwin Rol <erwin@muffin.org>.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-083-18/+2
* Removed references to INSTALL_VARIANT.Joel Sherrill2000-02-081-3/+6
* Patch rtems-rc-20000118-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-021-2/+2
| | | | | | | | | | | | | | | | that contains: The workarounds related to the issues with ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg (Which is basically broken) To apply: patch -p1 < rtems-rc-20000118-6.diff ./bootstrap Note: * Though this patch is small, ./bootstrap is absolutely necessary. * Now your CVS source tree is identical to my local CVS.
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-312-3/+3
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Modifications from Ralf to be more like other custom files. ThereJoel Sherrill2000-01-311-4/+4
| | | | is no way to build this target.
* Added after report from Quality Quorum <qqi@world.std.com> thatJoel Sherrill2000-01-271-0/+11
| | | | pc686.cfg was not present.
* Called symbol table ".nm" not .num like every other BSP.Joel Sherrill2000-01-121-1/+1
* Added pc486 and pc586 as aliases of pc386 with proper cpu flags.Joel Sherrill2000-01-103-1/+26
* Missed cleanup from Ralf Corsepius.Joel Sherrill2000-01-102-8/+10
* Removed reference to Radstone PPCN.Joel Sherrill2000-01-101-6/+0
* Fixed comment.Joel Sherrill2000-01-101-2/+2
* Renaming mcp750 to motorola_shared since that is the basis for bothJoel Sherrill2000-01-072-5/+5
| | | | | the mvme2307 and mcp750 BSPs. In addition, it can support many Motorola PowerPC based VME and PCI boards.
* Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-071-3/+3
| | | | | | | | | | | | | | | | | | | | | which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
* Patch rtems-rc-19991203-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-0/+6
| | | | | which cleans up and merges some Hitachi SH-2 modifications from John Mills <jmills@tga.com>.
* *** empty log message ***Joel Sherrill1999-12-131-4/+4
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-022-1/+2
| | | | | As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
* Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1999-12-011-1/+4
| | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-301-4/+4
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-234-9/+15
| | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-233-6/+6
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Removed need for START_BASE.Joel Sherrill1999-11-2214-42/+1
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-228-19/+16
* Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill1999-11-182-9/+93
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
* Removed as part of patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-171-73/+0
* Patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-1613-72/+26
| | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which does the following: This is the configuration cleanup patch: Main changes: * TARGET_ARCH removed * target.cfg.in moved to c/make/target.cfg.in (Only configured once for all BSPs of a target) * BARE_XXX variables appended to bsp.cfg.in * autogen renamed to bootstrap * removed stray variables from make/custom/*.cfg To apply: cd <source-tree> rm c/src/make/target.cfg.in cp autogen bootstrap mkdir c/make cp make/target.cfg.in c/make/target.cfg.in rm make/target.cfg.in rm autogen patch -p1 < rtems-rc-19991105-1.diff
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+1
| | | | for RTEMS.
* Eliminated references to stack checker related #defines.Joel Sherrill1999-11-054-29/+0
* Removed HAS_MP=no and commented out HAS_NETWORKING=no.Joel Sherrill1999-11-011-8/+0
* Patch rtems-rc-19991011-3.diff from Ralf Corsepius.Joel Sherrill1999-10-281-2/+11
* Updated to be more like cvme961.cfg.Joel Sherrill1999-10-271-26/+10
* The rxgen960 BSP and i960 RPM support was submitted by Mark BronsonJoel Sherrill1999-10-271-0/+90
| | | | <mark@ramix.com> of RAMIX.
* Removed all references to HOST_ARCH including the file gcc.cfg.in. AllJoel Sherrill1999-10-266-243/+4
| | | | | host programs are now compiled with automake generated rules. This was done after discussions with Ralf Corsepius and Eric Norum.
* tch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1999-10-251-1/+1
| | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server.
* Changed to use interrupt driven console.Joel Sherrill1999-10-251-1/+1
* Switched to the C++ front end to gcc to link. This still did notJoel Sherrill1999-10-111-1/+1
| | | | work.
* Added $(LINK_LIBS) to linking gcc command so paranoia would link.Joel Sherrill1999-10-061-1/+1
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-051-3/+0
| | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP.
* Removed targets and configurations that are no longer functionalJoel Sherrill1999-10-054-215/+16
* Minor corrections to get mvme2307 to compile.Joel Sherrill1999-10-051-0/+1
* Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>.Joel Sherrill1999-10-041-0/+112
| | | | No modifications made.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-044-15/+15
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-044-1085/+0
* Regenerated.Joel Sherrill1999-10-044-20/+24
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-074-4/+4
