path: root/make (follow)
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-1344-226/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Removed NDEBUG as a per BSP option.Joel Sherrill2000-07-1344-217/+5
* Removed references to stack checker defines since it is dynamicallyJoel Sherrill2000-07-122-12/+0
| | | | enabled now at configure time.
* Removed stupid reference to NO_TABLE_MOVE in comment block.Joel Sherrill2000-07-128-26/+0
* Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-1244-166/+5
| | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime.
* Reworked score/cpu/sparc so it can be safely compiled multilib. AllJoel Sherrill2000-07-111-1/+0
| | | | | | routines and structures that require CPU model specific information are now in libcpu. This primarily required moving erc32 specific information from score/cpu files to libcpu/sparc and the erc32 BSP.
* Reworked score/cpu/i960 so it can be safely compiled multilib. AllJoel Sherrill2000-07-112-2/+3
| | | | | | | routines and structures that require CPU model specific information are now in libcpu. This required significant rework of the score/cpu header files and the creation of multiple header files and subdirectories in libcpu/i960.
* Patch rtems-rc-20000711-2-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-113-21/+0
| | | | that removes setting unused variables WORKSPACE_MB and HEAPSPACE_MB.
* Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-112-4/+13
| | | | | | | | | that decouples exec/ for the sh, m68k and i960 from targopts.h. NOTE: The change to system.h is a hack to enable cpuopts.h for some targets, but keep using targopts.h for others - I know it does *not* work for sparc, mips, i386 and ppc. This will have to be addressed as work continues on multilibing.
* Patch from James Housley <jim@thehousleys.net> to let the MakefilesJoel Sherrill2000-07-071-1/+1
| | | | find tools like packhex after installation.
* Patch from Eric Valette <valette@crf.canon.fr> and Yacine El KolliJoel Sherrill2000-07-062-2/+40
| | | | <elkolli@crf.canon.fr> to add support for the mbx860_005b.
* Added baseline for h8 simulator BSP to support the simulator in gdb 5.0Joel Sherrill2000-07-061-0/+67
* rxgen960 compiles and links.Joel Sherrill2000-06-151-1/+3
* Added multigen generated bare BSP configuration files.Joel Sherrill2000-06-151-0/+1
* Changed to standard make-exe type rule.Joel Sherrill2000-06-141-1/+1
* Moved PPC_VECTOR_FILE_BASE to targopts.hJoel Sherrill2000-06-141-1/+1
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-123-0/+220
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-124-7/+49
* Added i960sim BSP which (ignoring the 3 instructions not supportedJoel Sherrill2000-06-121-0/+67
| | | | by gdb 5.0's i960 simulator) is enough to run hello world.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1251-403/+314
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-134-0/+9
| | | | adds .cvsignore.
* Cleanup patch from Ralf Corsepius.Joel Sherrill2000-04-051-1/+1
* New file. Should support Cygwin as unix simulator port.Joel Sherrill2000-04-051-0/+65
* BSP now compiles and links with CAVSL board information. This includesJoel Sherrill2000-02-292-2/+2
| | | | | | | | | | linkcmds updated, simio references removed, and switch to libchip for serial ports from simio. Added a MEMORY_MAP file to capture information about the various addresses on this board. In addition, many of the beta patches are now included.
* New port of RTEMS to TI C3x and C4x.Joel Sherrill2000-02-222-0/+71
* Fixed typos introduced in last modification. Spotted byJoel Sherrill2000-02-111-6/+6
| | | | Erwin Rol <erwin@muffin.org>.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-083-18/+2
* Removed references to INSTALL_VARIANT.Joel Sherrill2000-02-081-3/+6
* Patch rtems-rc-20000118-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-021-2/+2
| | | | | | | | | | | | | | | | that contains: The workarounds related to the issues with ppc/helas403 (triggers a nasty bug in automake-2.14) and mcp750.cfg (Which is basically broken) To apply: patch -p1 < rtems-rc-20000118-6.diff ./bootstrap Note: * Though this patch is small, ./bootstrap is absolutely necessary. * Now your CVS source tree is identical to my local CVS.
* Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-312-3/+3
| | | | | | | | | | | | | | that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups
* Modifications from Ralf to be more like other custom files. ThereJoel Sherrill2000-01-311-4/+4
| | | | is no way to build this target.
* Added after report from Quality Quorum <qqi@world.std.com> thatJoel Sherrill2000-01-271-0/+11
| | | | pc686.cfg was not present.
* Called symbol table ".nm" not .num like every other BSP.Joel Sherrill2000-01-121-1/+1
* Added pc486 and pc586 as aliases of pc386 with proper cpu flags.Joel Sherrill2000-01-103-1/+26
* Missed cleanup from Ralf Corsepius.Joel Sherrill2000-01-102-8/+10
* Removed reference to Radstone PPCN.Joel Sherrill2000-01-101-6/+0
* Fixed comment.Joel Sherrill2000-01-101-2/+2
* Renaming mcp750 to motorola_shared since that is the basis for bothJoel Sherrill2000-01-072-5/+5
| | | | | the mvme2307 and mcp750 BSPs. In addition, it can support many Motorola PowerPC based VME and PCI boards.
* Patch rtems-rc-20000104-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-071-3/+3
| | | | | | | | | | | | | | | | | | | | | which is described below: This one is a (minor) patch in preparation of the upcoming patches. It actually is an excerpt of the upcoming patches and therefore is completely untested in this standalone form, but I don't expect it to break something. The essential changes in this patch are: * An update to rtems-polish.sh (Now can also be run in subdirectories) * A bug-fix for the libcpu/powerpc (A directory was missing from SUBDIRS in a Makefile.am) * An update to gensh2.cfg. * Cleanups/Enhancements to configuration files To apply: cd <srcdir> patch -p0 < rtems-rc-20000104-0.diff cvs rm -f c/src/lib/libbsp/Makefile.am.new
* Patch rtems-rc-19991203-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-0/+6
| | | | | which cleans up and merges some Hitachi SH-2 modifications from John Mills <jmills@tga.com>.
* *** empty log message ***Joel Sherrill1999-12-131-4/+4
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-022-1/+2
| | | | | As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
* Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1999-12-011-1/+4
| | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-301-4/+4
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* Patch rtems-rc-19991117-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-234-9/+15
| | | | | | | * the PACKHEX etc problem * prevents the *.rels being removed inside the build-tree * a typo which only shows for when MP is activated * Alters some custom/*cfg files
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-233-6/+6
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* Removed need for START_BASE.Joel Sherrill1999-11-2214-42/+1
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-228-19/+16
* Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill1999-11-182-9/+93
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
* Removed as part of patch rtems-rc-19991105-1.diff.gz from Ralf CorsepiusJoel Sherrill1999-11-171-73/+0
