* custom/gen83xx.cfg: Remove -funit-at-a-time.
* custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags.
* leaf.cfg, compilers/gcc-target-default.cfg, custom/bf537Stamp.cfg,
custom/gen5200.cfg, custom/gen83xx.cfg, custom/genmcf548x.cfg,
custom/mbx8xx.cfg, custom/mpc55xx.cfg, custom/nds.cfg,
custom/pc386.cfg, custom/tqm8xx.cfg: Remove use of AM_LDFLAGS. Ensure
LDFLAGS works all the time. Clean up BSPs which defined their own
make-exe rules inappropriately.
updated haleakala BSP
added MPC55xx BSP
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/gen83xx.cfg: Use -O2.
* custom/gen83xx.cfg: Add make-cxx-exe rule.
many different versions of new exception handling code to shared sources.
