* | 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-11-27 | 1 | -17/+0 |
| | | | | | | | | | | | | | * custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. | ||||
* | 2001-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-11-13 | 1 | -2/+4 |
| | | | | | | * custom/helas403.cfg, custom/gen405.cfg: Removed dependency on the --srec-len argument to objcopy only supported in binutils 2.11 or newer. | ||||
* | 2001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se> | Joel Sherrill | 2001-11-09 | 1 | -0/+85 |
This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * custom/gen405.cfg: New file. * custom/helas403.cfg: Modified to generate Srecords. |
