* | Remove (Abandonded). | Ralf Corsepius | 2008-02-19 | 1 | -54/+0 |
* | Add -g to CFLAGS_OPTIMIZE_V. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | 2007-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | * custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg, custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg, custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg, custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg, custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg, custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg, custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg, custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg, custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg, custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg: CFLAGS_OPTIMIZE_V = -O2. | ||||
* | Remove obsolete comments referring to gcc-2.8. | Ralf Corsepius | 2007-01-18 | 1 | -2/+1 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+0 |
* | Cosmetics. | Ralf Corsepius | 2007-01-18 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-11-30 | 1 | -2/+1 |
* | 2002-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-09 | 1 | -1/+2 |
| | | | | * custom/gen405.cfg: Corrected make-cxx-exe rule to use LINK.cc. | ||||
* | 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-18 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/eth_comm.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS. * custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS. * custom/mbx8xx.cfg: Remove make-target-options. Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS. Remove obsolete comments. * custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS. Remove obsolete comments. * custom/mpc8260ads.cfg: Remove make-target-options. Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to CPU_CFLAGS. * custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS. Remove obsolete comments. * custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. * custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS. Remove obsolete comments. | ||||
* | 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-04 | 1 | -1/+1 |
| | | | | * custom/gen405.cfg: Remove -D__powerpc__. | ||||
* | 2002-03-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -14/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * custom/cvme961.cfg: Remove GCC272 support. * custom/dmv152.cfg: Remove GCC272 support. * custom/efi332.cfg: Remove GCC272 support. * custom/efi68k.cfg: Remove GCC272 support. * custom/eth_comm.cfg: Remove GCC272 support. * custom/gen405.cfg: Remove GCC272 support. * custom/gen68302.cfg: Remove GCC272 support. * custom/gen68340.cfg: Remove GCC272 support. * custom/gen68360.cfg: Remove GCC272 support. * custom/genmongoosev.cfg: Remove GCC272 support. * custom/helas403.cfg: Remove GCC272 support. * custom/i386ex.cfg: Remove GCC272 support. * custom/i960sim.cfg: Remove GCC272 support. * custom/idp.cfg: Remove GCC272 support. * custom/leon2.cfg: Remove GCC272 support. * custom/mbx8xx.cfg: Remove GCC272 support. * custom/mcf5206elite.cfg: Remove GCC272 support. * custom/mpc8260ads.cfg: Remove GCC272 support. * custom/mrm332.cfg: Remove GCC272 support. * custom/mvme136.cfg: Remove GCC272 support. * custom/mvme147.cfg: Remove GCC272 support. * custom/mvme167.cfg: Remove GCC272 support. * custom/ods68302.cfg: Remove GCC272 support. * custom/p4000.cfg: Remove GCC272 support. * custom/p4600.cfg: Remove GCC272 support. * custom/p4650.cfg: Remove GCC272 support. * custom/pc386.cfg: Remove GCC272 support. * custom/portsw.cfg: Remove GCC272 support. * custom/psim.cfg: Remove GCC272 support. * custom/rxgen960.cfg: Remove GCC272 support. * custom/score603e.cfg: Remove GCC272 support. * custom/sim68000.cfg: Remove GCC272 support. * custom/simhppa.cfg: Remove GCC272 support. * custom/simsh4.cfg: Remove GCC272 support. * custom/ts_386ex.cfg: Remove GCC272 support. | ||||
* | 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-11-27 | 1 | -17/+0 |
| | | | | | | | | | | | | | * custom/gen405.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/helas403.cfg: Remove PPC_VECTOR_FILE_BASE, PPC_USE_SPRG; Remove make-target-options. * custom/mbx8xx.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mbx860_005b.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. * custom/mpc8260ads.cfg: Remove INSTRUCTION_CACHE_ENABLE, DATA_CACHE_ENABLE. | ||||
* | 2001-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-11-13 | 1 | -2/+4 |
| | | | | | | * custom/helas403.cfg, custom/gen405.cfg: Removed dependency on the --srec-len argument to objcopy only supported in binutils 2.11 or newer. | ||||
* | 2001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se> | Joel Sherrill | 2001-11-09 | 1 | -0/+85 |
This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * custom/gen405.cfg: New file. * custom/helas403.cfg: Modified to generate Srecords. |
