path: root/make/custom/dmv177.cfg (follow)
* Added $(CPPFLAGS) to all gcc 2.8 style make-exe rules.Joel Sherrill1999-03-081-1/+2
* Part of automake VI Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1999-02-181-1/+1
| | | | | | | > Adds variables to the custom/*cfg files to specify the location of > tools. The purpose is to remove hard-coded paths from the Makefiles. > > In later steps this eases moving the tools to other locations.
* Added instruction and data cache enable.Joel Sherrill1999-02-051-2/+13
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-3/+0
| | | | it work.
* Updates to tree to make it build with all desired changes and the conversionJoel Sherrill1998-09-111-1/+1
| | | | of the SONIC driver to the new FreeBSD stack instead of KA9Q.
* Added HAS_RTC and enabled KA9Q.Joel Sherrill1998-07-301-4/+2
* Switching console interrupts on and off as we test.Joel Sherrill1998-07-251-1/+1
* Switched CONSOLE_USE_INTERRUPTS to "1" so console would use interrupts.Joel Sherrill1998-07-151-2/+2
| | | | | Switched PPC_USE_SPRG to "0" so RTEMS use of sprg would not conflict with any possible sprg usage by the DY-4 ROM monitor.
* Now strip elf executables so they are much smaller and quicker toJoel Sherrill1998-07-091-0/+1
| | | | read from and write to a floppy.
* Added PPC_USE_DATA_CACHE.Joel Sherrill1998-06-131-3/+8
* Updated to current source and removed warnings.Joel Sherrill1998-05-301-17/+18
* New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot.Joel Sherrill1998-05-301-0/+112
