* Makefile.am: Remove dmv177 and ppcn_60x.
* custom/dmv177.cfg: Removed.
* custom/dmv177.cfg: Use -mcpu=603e.
* custom/ppcn_60x.cfg: Use -mcpu=603e.
* custom/psim.cfg: Use -mcpu=603e.
* custom/score603e.cfg: Use -mcpu=603e.
* custom/ts_386ex.cfg: Remove obsolete comments.
* custom/rxgen960.cfg: Remove obsolete comments.
* custom/cvme961.cfg: Remove obsolete comments.
* custom/dmv177.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/eth_comm.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/gen405.cfg: Add -D_OLD_EXCEPTIONS -Dppc405 to CPU_CFLAGS.
* custom/helas403.cfg: Add -D_OLD_EXCEPTIONS -Dppc403 to CPU_CFLAGS.
* custom/mbx8xx.cfg: Remove make-target-options.
Add -Dmpc$(CPU_TYPE) -D$(RTEMS_MBX_MODEL) to CPU_CFLAGS.
* custom/mcp750.cfg: Add -Dmpc750 to CPU_CFLAGS.
* custom/mpc8260ads.cfg: Remove make-target-options.
Add -Dmpc8260 -DPPC_ABI=PPC_ABI_EABI -DPPC_ASM=PPC_ASM_ELF to
CPU_CFLAGS.
* custom/mvme2307.cfg: Add -Dmpc604 to CPU_CFLAGS.
* custom/ppcn_60x.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/psim.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to CPU_CFLAGS.
* custom/score603e.cfg: Add -D_OLD_EXCEPTIONS -Dppc603e to
CPU_CFLAGS.
* custom/dmv177.cfg: Reflect changes to dmv177/configure.ac.
* custom/ppcn_60x.cfg: Refect changes to ppcn_60x/configure.ac.
* custom/psim.cfg: Refect changes to psim/configure.ac.
* custom/score603e.cfg: Reflect changes to score603e/configure.ac,
remove SCORE603E_GENERATION.
* custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS,
CONSOLE_USE_POLLED, HAS_RTC.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg,
custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
that does the following:
Remove $(SED) and $(CP) from make/custom/*.cfg
Motivation:
* autoconf and automake presuppose sed and cp to be present.
* make/host.cfg.in already contains SED = sed hard-coded into it for
a long time.
* Elimination of make-variables
* Eliminate make/*.cfg files or at least reduce their complexity :)
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
definitions of CONSOLE_USE_POLLED to be !CONSOLE_USE_INTERRUPTS
instead of ~CONSOLE_USE_INTERRUPTS.
> Adds variables to the custom/*cfg files to specify the location of
> tools. The purpose is to remove hard-coded paths from the Makefiles.
> In later steps this eases moving the tools to other locations.
it work.
of the SONIC driver to the new FreeBSD stack instead of KA9Q.
Switched PPC_USE_SPRG to "0" so RTEMS use of sprg would not conflict with
any possible sprg usage by the DY-4 ROM monitor.
read from and write to a floppy.
