* | Updates to tree to make it build with all desired changes and the conversion | Joel Sherrill | 1998-09-11 | 1 | -1/+1 |
| | | | | of the SONIC driver to the new FreeBSD stack instead of KA9Q. | ||||
* | Added HAS_RTC and enabled KA9Q. | Joel Sherrill | 1998-07-30 | 1 | -4/+2 |
* | Switching console interrupts on and off as we test. | Joel Sherrill | 1998-07-25 | 1 | -1/+1 |
* | Switched CONSOLE_USE_INTERRUPTS to "1" so console would use interrupts. | Joel Sherrill | 1998-07-15 | 1 | -2/+2 |
| | | | | | Switched PPC_USE_SPRG to "0" so RTEMS use of sprg would not conflict with any possible sprg usage by the DY-4 ROM monitor. | ||||
* | Now strip elf executables so they are much smaller and quicker to | Joel Sherrill | 1998-07-09 | 1 | -0/+1 |
| | | | | read from and write to a floppy. | ||||
* | Added PPC_USE_DATA_CACHE. | Joel Sherrill | 1998-06-13 | 1 | -3/+8 |
* | Updated to current source and removed warnings. | Joel Sherrill | 1998-05-30 | 1 | -17/+18 |
* | New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot. | Joel Sherrill | 1998-05-30 | 1 | -0/+112 |
