cpuopts.h.
to disabled.
problems at runtime.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
host programs are now compiled with automake generated rules. This was
done after discussions with Ralf Corsepius and Eric Norum.
it work.
As mentioned in other mails before, there is are minor inconsistencies in the
posix custom/*cfg files.
Linux-posix.cfg sets RTEMS_BSP=posix
FreeBSD-posix.cfg sets RTEMS_BSP=posix
Solaris-posix.cfg first sets RTEMS_BSP=posix, later it sets
RTEMS_BSP=solaris2
1. Setting RTEMS_BSP=posix is redunant to settings in default.cfg
2. The solaris variant of setting RTEMS_BSP is merely non-functional.
The patch attached to this mail should clean up this issue.
The patch was tested by building the posix bsp under
i686-pc-linux-glibc1/glibc2 and Solaris2.6 (I did not run any
rtems program, however) The HPUX9 and FreeBSD configuration files
were adapted in analogy to the solaris and linux configurations.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
* Posix BSP configuration: Moved some rules from make/custom/*-posix.cfg
files to make/custom/posix.cfg, Removed references to stdc++ from
*posix.cfg files (rtems doesn't use/need libstdc++)
NOTE: Building Posix-BSPs should now work again for native compilation with
gcc, i..e. linux using primary compiler and primary libc.
All Posix-BSP configurations that don't use gcc as primary compiler or
don't use the primary libc don't work, e.g. solaris, linux w/ egcs as
secondary compiler won't be built correctly.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
