* | new test cases | Joel Sherrill | 1998-02-11 | 2 | -0/+92 |
* | new directory structure for hwapi | Joel Sherrill | 1998-02-11 | 2 | -2/+2 |
* | hwapi added | Joel Sherrill | 1998-02-11 | 1 | -1/+2 |
* | updates | Joel Sherrill | 1998-02-11 | 17 | -655/+540 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 191 | -198/+192 |
* | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 1998-02-06 | 3 | -3/+363 |
| | | | | this capability was first used. | ||||
* | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 1998-02-05 | 2 | -22/+76 |
* | Big patch form Ralf Corsepius described in this email: | Joel Sherrill | 1998-01-30 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Here is the result of my nightly work to get RTEMS_ROOT=$srcdir working with different shells and relative/absolute paths. What I did is relatively simple in principle: Instead of setting RTEMS_ROOT in configure.in and then let configure substitute @RTEMS_ROOT@ inside the Makefiles, I now let each Makefile set RTEMS_ROOT from each Makefile's @top_srcdir@ value. The difference is subtile, but with enormous side effects: - If RTEMS_ROOT is set in configure, then the same single value will be propagated to all Makefiles. This breaks using relative paths, as the relative path to the root of the source tree is used inside of all subdirectory Makefiles. - Now each Makefile.in sets RTEMS_ROOT = @top_srcdir@. top_srcdir is computed individually by configure for each single Makefile.in, hereby receiving the correct value, no matter if relative or absolute paths are used. To get this working, I needed to remove setting RTEMS_ROOT from target.cfg.in, because this overrides the value of RTEMS_ROOT from each individual Makefile. Furthermore, I removed RTEMS_CUSTOM from the Makefiles and replaced all "include $(RTEMS_CUSTOM)" directives with"include $(RTEMS_ROOT)/make/custom/$(RTEMS_BSP)". Perhaps you don't like this, but I think, to have one variable less is clearer and easier to understand than having several variables refering to the next one. I enclose a small patch to this mail, which - fixes the config.h problem (to finally clearify misunderstands) - removes assignment/subsitution of RTEMS_ROOT from configure.in - contains a workaround for the application Makefile's RTEMS_ROOT problem (reported by Eric) - removes some unused lines from the toplevel Makefile.in - removes assignment of RTEMS_ROOT from make/target.cfg.in | ||||
* | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 1998-01-30 | 2 | -4/+36 |
| | | | | be one paragraph with manual line breaks rather than multiple paragraphs.. | ||||
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 20 | -106/+110 |
* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 |
| | | | | doing the HWAPI manual. | ||||
* | Changed reference from PROJECT_ROOT to RTEMS_ROOT. | Joel Sherrill | 1998-01-21 | 1 | -1/+1 |
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 |
| | | | | Application Cindy has written can transform into a nice Word document. | ||||
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | ||||
* | More specific information on error code. | Joel Sherrill | 1997-09-03 | 1 | -1/+2 |
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | ||||
* | Fixed wildcard in copy command. | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Added comments to help avoid editting generated file. | Joel Sherrill | 1997-08-04 | 2 | -0/+8 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 |
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 |
* | Corrected bug in Makefile | Joel Sherrill | 1997-07-31 | 1 | -1/+1 |
* | Corrected problem where directories where not being properly created. | Joel Sherrill | 1997-07-31 | 3 | -7/+10 |
| | | | | Change path to indicate expected snapshot date. | ||||
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 23 | -39/+51 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 |
| | | | | for the pointer to a "return area".. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
| | | | | | This version has had some initial work done to convert it to be PowerPC specific. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
* | | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 181 | -70/+541 |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | | Added CVS Id string | Joel Sherrill | 1997-06-04 | 2 | -0/+6 |
* | | changed version number | Joel Sherrill | 1997-06-04 | 4 | -5/+6 |
* | | changed edition and version information | Joel Sherrill | 1997-06-04 | 16 | -28/+29 |
* | | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 11 | -29/+28 |
* | | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 30 | -222/+404 |
| | | | | | | | | | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 2 | -7/+8 |
| | | | | | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. | ||||
* | | fixed typos | Joel Sherrill | 1997-05-30 | 23 | -83/+83 |
* | | updated to reflect Ada | Joel Sherrill | 1997-05-30 | 2 | -15/+262 |
