* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+5 | |
| | | | | * started.texi: Set @setfilename started.info. | |||||
| | | | | * rtems_gdb.texi: Set @setfilename rtems_gdb.info. | |||||
| | | | | * rgdb_specs.texi: Set @setfilename rgdb_specs.info. | |||||
| | | | | * relnotes.texi: Set @setfilename relnotes.info. | |||||
| | | | | * posix_users.texi: Set @setfilename posix_users.info. | |||||
| | | | | * posix1003_1.texi: Set @setfilename posix1003_1.info. | |||||
| | | | | * porting.texi: Set @setfilename porting.info. | |||||
| | | | | * new_chapters.texi: Set @setfilename new_chapters.info. | |||||
| | | | | * networking.texi: Set @setfilename networking.info. | |||||
| | | | | * itron.texi: Set @setfilename itron.info. | |||||
| | | | | * filesystem.texi: Set @setfilename filesystem.info. | |||||
| | | | | * develenv.texi: Set @setfilename develenv.info. | |||||
| | | | | * bsp_howto.texi: Set @setfilename bsp_howto.info. | |||||
| | | | | * ada_user.texi: Set @setfilename ada_user.info. | |||||
| | | | | * FAQ.texi: Set @setfilename FAQ.info. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 3 | -0/+9 | |
| | | | | | * configure.ac: Add c4x. * project.am: Add version.texi hack. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+16 | |
| | | | | * Makefile.am: Add c4x, cosmetical changes. | |||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 5 | -23/+131 | |
| | | | | | | * Makefile.am: New. * c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them building. | |||||
* | 2003-01-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-24 | 12 | -0/+1378 | |
| | | | | | | * BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t: New files. These should have been added long ago. | |||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 2 | -4/+4 | |
| | | | | * supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. | |||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 44 | -243/+331 | |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | |||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 8 | -50/+66 | |
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 3 | -5/+20 | |
| | | | | | | | * main.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Append -I $(top_builddir) to TEXI2WWW_ARGS. * project.am: Add AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. Override automake's .dvi.ps:-rule. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 2 | -3/+8 | |
| | | | | | * supplements.am: Use automake rules to build ps, pdf, info. Various minor changes. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 3 | -23/+13 | |
| | | | | | * project.am, main.am: Use automake rules to build ps, pdf, info. Various minor changes. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -1/+5 | |
| | | | | * build45.t: Fix typo in previous patch. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -9/+70 | |
| | | | | * build45.t: Several fixes and additions. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 2 | -2/+7 | |
| | | | | | * project.am: Append $($(PROJECT)_TEXINFOS) to html-dependencies. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 3 | -20/+41 | |
| | | | | | | * FAQ.texi: Rename section "Building RTEMS 4.5" into "Building RTEMS". build45.t: Remove references to 4.5. Several minor updates. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 112 | -391/+447 | |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 3 | -897/+5 | |
| | | | | | * wksheets.texi: Remove from CVS. * timing.texi: Remove from CVS. | |||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 4 | -25/+25 | |
| | | | | | | | | * configure.ac: Require autoconf-2.57. Require automake-1.7.2. Remove started/pictures/Makefile. * started/Makefile.am: Merge-in pictures/Makefile.am * started/pictures/Makefile.am: Remove. | |||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 84 | -112/+224 | |
| | | | | * stamp-vti, version.texi: Regenerated. | |||||
* | 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-08 | 2 | -1/+5 | |
| | | | | * supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS. | |||||
* | 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-08 | 6 | -23/+23 | |
| | | | | | | | | * Makefile.am: Merge-in images/Makefile.am, common/Makefile.am. * images/Makefile.am: Remove. * common/Makefile.am: Remove. * configure.ac: Reflect changes above. * main.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS. | |||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 2 | -1/+10 | |
| | | | | | * index.html.in: Note that the Getting Started with GNAT/RTEMS manual is largely obsolete now that GNAT is in GCC. | |||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 2 | -1/+5 | |
| | | | | * Makefile.am: Corrected link. | |||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 8 | -716/+37 | |
| | | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed. | |||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 84 | -114/+226 | |
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 2 | -123/+53 | |
| | | | | * intr_NOTIMES.t: Real version submitted. | |||||
* | 2002-10-24 Eugeny S. Mints <Eugeny.Mints@oktet.ru> | Joel Sherrill | 2002-10-28 | 8 | -9/+386 | |
| | | | | | | | | * ata.t, ide-ctrl.t: New file. * .cvsignore: Added new .texi files. * Makefile.am:: Added new files to generate. * bsp_howto.texi: Added new chapters. * stamp-vti, version.texi: Regenerated. | |||||
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 84 | -120/+232 | |
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 2 | -19/+68 | |
| | | | | * index.html.in: Add links to multiple missing CPU supplements. | |||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 4 | -6/+18 | |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
* | 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-09 | 2 | -0/+5 | |
| | | | | * .cvsignore: Add autom4te.cache. | |||||
* | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-27 | 2 | -6/+4 | |
| | | | | * io.t: Correct Ada bindings. | |||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 3 | -278/+284 | |
| | | | | | | * BSP_TIMES, wksheets.texi: Updated to reflect ARM times reported by Jay Monkman <jmonkman@adventnetworks.com>. These times are subject to change as he tunes the ARM port and their BSP. | |||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 3 | -4/+8 | |
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 3 | -4/+8 | |
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 2 | -1/+5 | |
| | | | | * Makefile.am: Added arm subdirectory. |
