* | Changed BOOTP -> BOOTP/DHCP. | Joel Sherrill | 1998-11-19 | 2 | -11/+12 |
* | Changed version string. | Joel Sherrill | 1998-11-19 | 9 | -33/+447 |
| | | | | | | Added much new stuff to the POSIX User's Guide. New chapters stuff shrunk. | ||||
* | Stripped down to be just new chapters. | Joel Sherrill | 1998-11-19 | 2 | -102/+8 |
* | Renamed entire document so this is a transient working directory. | Joel Sherrill | 1998-11-19 | 1 | -43/+5 |
* | Merged these into POSIX manual. | Joel Sherrill | 1998-11-19 | 19 | -9745/+0 |
* | Added. | Joel Sherrill | 1998-11-19 | 1 | -0/+175 |
* | Readded preface | Joel Sherrill | 1998-11-19 | 1 | -0/+34 |
* | Major update/merge of POSIX manual. | Joel Sherrill | 1998-11-19 | 19 | -741/+6740 |
* | New files | Joel Sherrill | 1998-11-19 | 6 | -0/+1020 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 30 | -422/+2115 |
* | making release docs | Joel Sherrill | 1998-10-29 | 4 | -29/+8 |
* | Version changed. | Joel Sherrill | 1998-10-27 | 6 | -31/+23 |
* | fixes from David Fiddes | Joel Sherrill | 1998-10-27 | 1 | -8/+6 |
* | Minor change to ease debugging. | Joel Sherrill | 1998-10-27 | 1 | -1/+3 |
* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Updated for beta4b | Joel Sherrill | 1998-10-27 | 1 | -3/+3 |
* | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1998-10-27 | 2 | -2/+1 |
* | Update from David Fiddes. | Joel Sherrill | 1998-10-27 | 4 | -113/+104 |
* | Clarifed description of driver name. | Joel Sherrill | 1998-10-27 | 1 | -1/+4 |
* | Version changed. | Joel Sherrill | 1998-10-27 | 1 | -4/+4 |
* | Version change. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Corrections from Jennifer and Jeff plus additions to the initialization | Joel Sherrill | 1998-10-21 | 5 | -87/+285 |
| | | | | chapter. | ||||
* | Spell checked. | Joel Sherrill | 1998-10-20 | 3 | -3/+3 |
* | Added much text to the linkcmds chapter. | Joel Sherrill | 1998-10-20 | 3 | -44/+68 |
| | | | | Cleaned up sections in the target dependent info file. | ||||
* | Links between chapters up to Linker Script in place. | Joel Sherrill | 1998-10-20 | 3 | -45/+119 |
| | | | | First draft of chapters up to and include Makefiles written. | ||||
* | Significant additions. | Joel Sherrill | 1998-10-20 | 1 | -45/+156 |
* | Renamed the target dependent code chapter. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Added some links between chapters. | Joel Sherrill | 1998-10-20 | 1 | -9/+8 |
* | Spacing changed. | Joel Sherrill | 1998-10-20 | 1 | -3/+2 |
* | Added new chapters. | Joel Sherrill | 1998-10-20 | 1 | -15/+55 |
* | Added multiple chapters and reordered them somewhat. | Joel Sherrill | 1998-10-20 | 1 | -2/+16 |
* | New files. | Joel Sherrill | 1998-10-20 | 7 | -0/+84 |
* | Added numerous comments to the linker script. | Joel Sherrill | 1998-10-20 | 1 | -243/+271 |
| | | | | Now this chapter has no two column stuff in it. | ||||
* | Added initial cut at some of the libc chapters. | Joel Sherrill | 1998-10-20 | 1 | -0/+27 |
* | Removed KA9Q manual. | Joel Sherrill | 1998-10-20 | 1 | -2/+0 |
* | New picture. | Joel Sherrill | 1998-10-20 | 1 | -0/+0 |
* | Updated. | Joel Sherrill | 1998-10-20 | 2 | -27/+30 |
* | Added more disk space to the requirements and included information | Joel Sherrill | 1998-10-20 | 1 | -3/+8 |
| | | | | indicating that it was per target. | ||||
* | Minor cleanup. | Joel Sherrill | 1998-10-20 | 2 | -4/+4 |
* | Added information about the bit_rtems script. | Joel Sherrill | 1998-10-20 | 2 | -5/+79 |
* | Added information about the new build scripts. | Joel Sherrill | 1998-10-20 | 1 | -56/+86 |
| | | | | Added host OS specific notes. | ||||
* | Added sections and had to change build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -1/+1 |
* | Increased required disk space along with information about the required | Joel Sherrill | 1998-10-20 | 1 | -3/+23 |
| | | | | | | disk space. Added information about GNU makeinfo minimum version. | ||||
* | Added information about the bit_gdb script. | Joel Sherrill | 1998-10-20 | 1 | -3/+35 |
* | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1998-10-20 | 1 | -59/+73 |
| | | | | | | describing the user.cfg file. Added a section on Solaris 2.x. | ||||
* | Added sections so had to change the build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Enhanced times() with copy from the other chapter. | Joel Sherrill | 1998-10-19 | 1 | -13/+16 |
* | Removed times() since it is duplicated. | Joel Sherrill | 1998-10-19 | 1 | -31/+0 |
* | Updated to reflect the longer list of libraries. | Joel Sherrill | 1998-10-19 | 1 | -3/+3 |
* | Removed node information. | Joel Sherrill | 1998-10-19 | 1 | -28/+1 |
