path: root/doc (follow)
* 2002-03-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-272-13/+18
| | | | | * PR161 * rtmon.t: Add rtems_ prefix to directives in the example.
* 2002-03-22 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-273-13/+156
| | | | | * io.t, conf.t: PR 160. Added the IO Manager's register and unregister interface documentation.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+21
| | | | | | * PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils.
* 2002-03-15 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-03-152-12/+16
| | | | * rtmon.t: Correct example and correctly used ensure not insure.
* 2001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-012-0/+40
| | | | * .cvsignore: New file.
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-142-0/+5
| | | | * configure.ac: New mips supplement.
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-142-1/+5
| | | | * mips: New supplement.
* 2002-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-1415-0/+1278
| | | | | | * bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi, preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
* fixing branchJoel Sherrill2002-01-301-7/+23
* fixing branchJoel Sherrill2002-01-301-23/+7
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-228-6008/+32
| | | | | | | | | | * .cvsignore: Reworked. * Makefile.am: Remove texinfo/texinfo.tex * bootstrap: Removed. * configure.ac: Add pkgdocdir. Let htmldir be rooted at pkgdocdir. * main.am: Remove TEXINFO_TEX. * project.am: Let dvidir, psdir, pdfdir be rooted at pkgdocdir. Remove commented out make-variables.
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2220-5308/+13
| | | | | | * configure.ac: Autoupdate to 2.52. Remove pdl2texi. * Makefile.am: Remove pdl2texi.
* regeneratedJoel Sherrill2002-01-2052-96/+148
* regeneratedJoel Sherrill2002-01-2034-60/+60
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-206-22/+14
| | | | | | | | | * .cvsignore: Add autom4te.cache, install-sh, mdate-sh, missing, mkinstalldirs, texinfo.tex. * Makefile.am: Add main.am to AUTOMAKE_FILES. * configure.ac: Add AC_CONFIG_AUX_DIR([.]). * project.am: Remove custom .texi and stamp-vti rules. * main.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2020-37/+41
| | | | * supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-181-0/+32
| | | | * Makefile.am: Require automake-1.5.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-186-61/+75
| | | | | | | | | * Makefile.am: Require automake-1.5. * project.am: Reworked. * main.am: New. * configure.ac: New. * configure.in: Removed. * bootstrap: Sync with RTEMS's toplevel bootstrap.sh.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-1837-50/+90
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-182-1/+5
| | | | * Makefile.am: require automake-1.5.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-185-4/+11
| | | | | | | * Makefile.am: Require automake-1.5. * ctags-emacs/Makefile.am: Ditto. * FreeBSD/Makefile.am: Ditto. * Ctags/Makefile.am: Ditto.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-1832-16/+97
| | | | * Makefile.am: include main.am, require automake-1.5.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-183-4/+11
| | | | | * Makefile.am: Include main.am, require automake-1.5. * pictures/Makefile.am: Require automake-1.5, fix +=.
* 2002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-1/+5
| | | | * VERSION: Updated to rtems-doc-ss-20010117.
* 2002-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-1/+7
| | | | * VERSION: Updated to rtems-doc-eng-20010816b-d1.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1752-0/+156
| | | | * .cvsignore: Added rtems_header.html and rtems_footer.html.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-1/+5
| | | | * configure.in: Changed the version to eng-20010816b.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-16/+238
| | | | | | * timer.t: Added task-based timer information including the new directives rtems_timer_initiate(), rtems_timer_server_fire_after(), and rtems_timer_server_fire_when().
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-17402-1051/+2202
* 2001-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-302-0/+9
| | | | * VERSION: New file.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+4
| | | | * Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-227-4/+15
| | | | * Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* Adding ChangeLogs.Joel Sherrill2000-08-2539-0/+117
* Interrupt stack is allocated by _ISR_Handler_initializationJoel Sherrill2000-07-031-1/+1
| | | | not that of _ISR_Manager_initialization.
* Added fchdir().Joel Sherrill2000-06-301-0/+63
* Patch rtemsdoc-4.5.0-rc-14-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-171-10/+16
| | | | | <corsepiu@faw.uni-ulm.de> to address build problems effecting RedHat users but not SuSE users.
* *** empty log message ***Joel Sherrill2000-06-163-3/+4
* Bug report from James Housley <jim@thehousleys.net> correctingJoel Sherrill2000-06-161-1/+1
| | | | name of GNU Java Compiler.
* Updated mailing list information.Joel Sherrill2000-06-151-16/+24
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-1430-34/+38
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch rtemsdoc-4.5.0-rc-12-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-123-13/+11
| | | | | | | | | <corsepiu@faw.uni-ulm.de> that makes the following changes: * Don't use a temporary file for ch19.texi anymore * pass all files to be handled by summarize as commandline arguments * Remove a dangling empty first line in posix1003_1.texi (texi2html (!) expects \input texinfo on the first line)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct problemsJoel Sherrill2000-06-123-7/+7
| | | | on RELEASE versus VERSION.
* Added out of date comment.Joel Sherrill2000-06-121-1/+1
* Purged as many egcs references as possible.Joel Sherrill2000-06-1012-17/+18
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-1082-293/+304
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Removed old bmenu version.Joel Sherrill2000-06-012-1067/+1
* Removed since unused.Joel Sherrill2000-06-011-22/+0
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to:Joel Sherrill2000-06-012-8/+16
| | | | | | | | | | This patch changes the installation directory of the supplements to supplements/<cpu>. This allows browsing the html files inside of the source tree, because after having applied this patch, the structure of the html installation directory hierarchy is the same as the directory structure of the source tree.
* Readding.Joel Sherrill2000-06-011-0/+65
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-01140-1579/+1473
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
