* VERSION: Updated to rtems-doc-ss-20010117.
* VERSION: Updated to rtems-doc-eng-20010816b-d1.
* configure.in: Changed the version to eng-20010816b.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
* VERSION: New file.
* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
not that of _ISR_Manager_initialization.
<corsepiu@faw.uni-ulm.de> to address build problems
effecting RedHat users but not SuSE users.
name of GNU Java Compiler.
relative srcdir issue
<corsepiu@faw.uni-ulm.de> that makes the following changes:
* Don't use a temporary file for ch19.texi anymore
* pass all files to be handled by summarize as commandline arguments
* Remove a dangling empty first line in posix1003_1.texi (texi2html
(!) expects \input texinfo on the first line)
on RELEASE versus VERSION.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
This patch changes the installation directory of the supplements to
supplements/<cpu>.
This allows browsing the html files inside of the source tree,
because after having applied this patch, the structure of the html
installation directory hierarchy is the same as the directory
structure of the source tree.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
Adds a -I <path> option to texi2www. This option is supposed to
compatible to the option of the same name in makeinfo, texi2dvi etc.
[This patch actually is kind of a hack, but it works :]
binaries rather than unpacking everything.
<trevin@eyring.com> to make hyperlinks take you to the top of
a page rather than the bottom.
<trevin@eyring.com> obtained from bug-texinfo mailing list.
the bug-texinfo mailing list:
There is also a bug in the PDF outline: Any outline item containing an
underscore shows up as a bunch of texinfo codes ("@unhbox @kern.06em
@vbox{..."). This bug was remedied by the following addition to
\pdfmakeoutlines.
over number of termios ports.
- char * nameserver[3] appears twice, second occurrence should be ntpserver
- in sect 3.3.3 ...ifcontig should be ifconfig
pointers to emacs and vim.
