path: root/doc (follow)
* Added Constants, Feature Flags, and Macros (included in Functions).Joel Sherrill1998-03-1817-126/+554
| | | | No status information was included.
* First attempt at adding constants and feature flagsJoel Sherrill1998-03-175-10/+324
* Completed status pass on functions and data types.Joel Sherrill1998-03-1712-33/+48
* Completed first pass at function status.Joel Sherrill1998-03-179-96/+117
| | | | Added most data types without status information.
* Added types, status of functions, cleaned up output of summarize.Joel Sherrill1998-03-169-229/+316
* Added function status and data typesJoel Sherrill1998-03-163-21/+54
* Cleaned up format and added data types.Joel Sherrill1998-03-161-8/+38
* Added Function field.Joel Sherrill1998-03-1615-344/+344
* summarize now generates a nicely formatted function status summary.Joel Sherrill1998-03-162-3/+13
* Function implmentation status information correct.Joel Sherrill1998-03-161-10/+10
* First time summary chapter is included in the document.Joel Sherrill1998-03-163-3/+6
* Added blank lines.Joel Sherrill1998-03-142-0/+12
* Added summary chapter.Joel Sherrill1998-03-141-2/+11
* New file.Joel Sherrill1998-03-141-0/+33
* Added functions from POSIX standard.Joel Sherrill1998-03-147-0/+295
* Added functions from POSIX standard.Joel Sherrill1998-03-143-2/+116
* Added copyright headerJoel Sherrill1998-03-141-0/+8
* Added functions from POSIX standard.Joel Sherrill1998-03-147-7/+686
* Outline complete and apparently correct.Joel Sherrill1998-03-1116-152/+156
* BaselineJoel Sherrill1998-03-1121-0/+754
* new test casesJoel Sherrill1998-02-112-0/+92
* new directory structure for hwapiJoel Sherrill1998-02-112-2/+2
* hwapi addedJoel Sherrill1998-02-111-1/+2
* updatesJoel Sherrill1998-02-1117-655/+540
* Updated copyrightsJoel Sherrill1998-02-06191-198/+192
* Added @table/@end table capability along with the avdas.d test case whereJoel Sherrill1998-02-063-3/+363
| | | | this capability was first used.
* Added code to more correctly process abstract types (handle, range, etc).Joel Sherrill1998-02-052-22/+76
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-2/+1
* Modified output of @Example style in MsWord output routine so it wouldJoel Sherrill1998-01-302-4/+36
| | | | be one paragraph with manual line breaks rather than multiple paragraphs..
* minor updates .. mostly versionJoel Sherrill1998-01-2320-106/+110
* Fixed some "NodeNameIncludesChapterName" problems which were uncoveredJoel Sherrill1998-01-231-11/+29
| | | | doing the HWAPI manual.
* Changed reference from PROJECT_ROOT to RTEMS_ROOT.Joel Sherrill1998-01-211-1/+1
* Added Code to dop the output in a format which a custom Visual BasicJoel Sherrill1998-01-213-10/+203
| | | | Application Cindy has written can transform into a nice Word document.
* Modified SPARC to PowerPC. Modified specific requirements to beJennifer Averett1997-12-022-14/+14
| | | | for the PowerPC instead of the SPARC.
* Added definations for serial_per_sec, serial_rate, and serial_xon_xoff.Jennifer Averett1997-12-022-12/+12
* Modified referances to SPARC to PowerPC. Updated the Information Table toJennifer Averett1997-12-022-12/+46
| | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid.
* Test document.Joel Sherrill1997-10-311-0/+690
* New test file.Joel Sherrill1997-10-311-4/+4
* Replaced the algorithm used to build the texinfo nodes and menus. ThisJoel Sherrill1997-10-311-218/+236
| | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names.
* More specific information on error code.Joel Sherrill1997-09-031-1/+2
* Added command line options for next, previous, and up node.Joel Sherrill1997-08-151-7/+28
| | | | | Added error check to insure we don't write over a .texi file given to us as input.
* Fixed wildcard in copy command.Joel Sherrill1997-08-041-1/+1
* Added comments to help avoid editting generated file.Joel Sherrill1997-08-042-0/+8
* Added information based on comments from Katsu Shibuya.Joel Sherrill1997-08-047-11/+57
* Fixed node links.Joel Sherrill1997-08-043-3/+3
* removed binary filesJoel Sherrill1997-08-043-0/+0
* Corrected bug in MakefileJoel Sherrill1997-07-311-1/+1
* Corrected problem where directories where not being properly created.Joel Sherrill1997-07-313-7/+10
| | | | Change path to indicate expected snapshot date.
* corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1997-07-3123-39/+51
* Added more info.Joel Sherrill1997-07-316-272/+276
