* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 20 | -106/+110 |
* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 |
| | | | | doing the HWAPI manual. | ||||
* | Changed reference from PROJECT_ROOT to RTEMS_ROOT. | Joel Sherrill | 1998-01-21 | 1 | -1/+1 |
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 |
| | | | | Application Cindy has written can transform into a nice Word document. | ||||
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | ||||
* | More specific information on error code. | Joel Sherrill | 1997-09-03 | 1 | -1/+2 |
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | ||||
* | Fixed wildcard in copy command. | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Added comments to help avoid editting generated file. | Joel Sherrill | 1997-08-04 | 2 | -0/+8 |
* | Added information based on comments from Katsu Shibuya. | Joel Sherrill | 1997-08-04 | 7 | -11/+57 |
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 |
* | Corrected bug in Makefile | Joel Sherrill | 1997-07-31 | 1 | -1/+1 |
* | Corrected problem where directories where not being properly created. | Joel Sherrill | 1997-07-31 | 3 | -7/+10 |
| | | | | Change path to indicate expected snapshot date. | ||||
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 23 | -39/+51 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Added info on what data type is expected by the clock_get directive | Joel Sherrill | 1997-07-31 | 1 | -0/+36 |
| | | | | for the pointer to a "return area".. | ||||
* | Added rtems_message_queue_get_number_pending directive. | Joel Sherrill | 1997-07-31 | 1 | -5/+50 |
* | Fixed typo of "::" | Joel Sherrill | 1997-07-18 | 1 | -1/+1 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
| | | | | | This version has had some initial work done to convert it to be PowerPC specific. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
* | | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 181 | -70/+541 |
* | | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | | Added CVS Id string | Joel Sherrill | 1997-06-04 | 2 | -0/+6 |
* | | changed version number | Joel Sherrill | 1997-06-04 | 4 | -5/+6 |
* | | changed edition and version information | Joel Sherrill | 1997-06-04 | 16 | -28/+29 |
* | | Fixed formatting problem where @example did not start early enough. | Joel Sherrill | 1997-06-04 | 1 | -2/+2 |
* | | final corrections before 4.1.0 documentation freeze. | Joel Sherrill | 1997-06-04 | 11 | -29/+28 |
* | | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 30 | -222/+404 |
| | | | | | | | | | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 2 | -7/+8 |
| | | | | | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. | ||||
* | | fixed typos | Joel Sherrill | 1997-05-30 | 23 | -83/+83 |
* | | updated to reflect Ada | Joel Sherrill | 1997-05-30 | 2 | -15/+262 |
* | | new file -- Ada specific | Joel Sherrill | 1997-05-30 | 3 | -3/+22 |
* | | first cut at Ada bindings manual | Joel Sherrill | 1997-05-29 | 22 | -46/+1322 |
* | | updated version number | Joel Sherrill | 1997-05-29 | 2 | -2/+2 |
* | | first cut at adding an Ada bindings manual | Joel Sherrill | 1997-05-29 | 3 | -1/+228 |
* | | version changed | Joel Sherrill | 1997-05-28 | 10 | -20/+20 |
* | | *** empty log message *** | Joel Sherrill | 1997-05-28 | 1 | -1/+1 |
* | | updated to add ka9q documents | Joel Sherrill | 1997-05-28 | 5 | -11/+22 |
* | | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 14 | -24/+24 |
* | | Initial revision | Joel Sherrill | 1997-05-27 | 198 | -0/+44720 |
