It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
disabled for timeslicing to happen. This was wrong.
on simple binary semaphores.
Eric Norum <eric@cls.usask.ca>.
so users know they are part of the public API.
pdf version of figures.
Added convert stanza to generate pdf's from eps of figures.
Added rule to convert rtemspie.eps to .pdf.
for PDF -- at least according to ghostview.
<ccj@acm.org> suggestion.
figures included.
the user extension table type definition correct.
but do not print them. texi2dvi barfs if the entries are even there.
blows up both makeinfo and texi2dvi. So I have commented them out.
