* PR161
* rtmon.t: Add rtems_ prefix to directives in the example.
* io.t, conf.t: PR 160. Added the IO Manager's register and
unregister interface documentation.
* rtmon.t: Correct example and correctly used ensure not insure.
* timer.t: Added task-based timer information including the
new directives rtems_timer_initiate(), rtems_timer_server_fire_after(),
and rtems_timer_server_fire_when().
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
over number of termios ports.
structure.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
disabled for timeslicing to happen. This was wrong.
on simple binary semaphores.
Eric Norum <eric@cls.usask.ca>.
so users know they are part of the public API.
