path: root/doc/user (follow)
* Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-262-32/+37
| | | | | | | | | | | | | that addresses the following: The patch below should * fix the *pdf cleanup handling * fix dependencies between pdf-documents and texi-files It also contains an attempt to let networking/schedule.t use states.pdf instead of ascii graphics, but though each pdf image looks nice, it comes out weirdly distorted in the main pdf document.
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-263-76/+39
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Merged changes from 4.5 branch and removed that branch.Joel Sherrill2000-04-251-2/+2
* Eric Norum spotted this sentence where it said preemption had to beJoel Sherrill2000-02-291-1/+3
| | | | disabled for timeslicing to happen. This was wrong.
* Fixed typo.Joel Sherrill2000-02-181-1/+1
* Patch from Eric Norum <eric@cls.usask.ca> to include some informationJoel Sherrill2000-02-181-0/+8
| | | | on simple binary semaphores.
* Added note from Ian Lance Taylor <ian@zembu.com>.Joel Sherrill2000-01-271-2/+6
* Added rtems_task_variable_get from Eric Norum.Joel Sherrill2000-01-231-1/+48
* Updated to reflect changing to void * on task variables byJoel Sherrill2000-01-231-8/+10
| | | | Eric Norum <eric@cls.usask.ca>.
* Changed copyright date to 1999.Joel Sherrill1999-11-1628-28/+28
* Added reference to rtems_get_class, rtems_get_node, and rtems_get_indexJoel Sherrill1999-11-161-7/+29
| | | | so users know they are part of the public API.
* Added task variable services.Joel Sherrill1999-11-162-1/+131
* Added categorized list of constants in confdefs.h.Joel Sherrill1999-11-161-0/+126
* Fixed line too long problems.Joel Sherrill1999-10-252-13/+20
* Formatting improvements.Joel Sherrill1999-10-253-12/+80
* Added files generated by index process to clean stanza.Joel Sherrill1999-10-111-1/+3
* Corrected spacing.Joel Sherrill1999-10-111-1/+0
* Turned on concept and function name indexing.Joel Sherrill1999-10-1123-154/+771
* Fixed variable reference for RTEMS-RELEASE.Joel Sherrill1999-10-111-1/+1
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+2
| | | | | | pdf version of figures. Added convert stanza to generate pdf's from eps of figures.
* Regenerated.Joel Sherrill1999-10-072-0/+0
* New files.Joel Sherrill1999-10-072-0/+0
* Added rtems_task_is_suspended.Joel Sherrill1999-10-071-0/+42
* Cleaned up use of $(PROJECT) instead of hard-coding c_user.Joel Sherrill1999-10-071-3/+5
| | | | Added rule to convert rtemspie.eps to .pdf.
* Enabled images. They appear to work ok for PostScript but not as wellJoel Sherrill1999-10-065-24/+13845
| | | | for PDF -- at least according to ghostview.
* Added multiple formats of the image so we can use the @image command.Joel Sherrill1999-10-063-0/+2164
* Corrected a typo.Joel Sherrill1999-10-062-21/+23
* Changed rtems_isr_level to rtems_interrupt_level per Chris Johns'Joel Sherrill1999-10-011-3/+3
| | | | <ccj@acm.org> suggestion.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-018-11/+17
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Clarified catch and disable per suggestion from Chris Johns <ccj@acm.org>.Joel Sherrill1999-10-011-0/+10
* Added a lot of information on confdefs.tJoel Sherrill1999-07-031-16/+367
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Added error status for bad return pointer argument on rtems_task_set_priority.Joel Sherrill1999-07-011-0/+1
* Corrected formatting so argument was in code font.Joel Sherrill1999-07-011-1/+1
* Fixed reference to initialize_executive to use the current name.Joel Sherrill1999-07-011-1/+2
* Unlimited objects information from Chris Johns (ccj@acm.org).Joel Sherrill1999-04-191-12/+36
* Added maximum_timers field to configuration table.Joel Sherrill1999-02-091-1/+1
* Added POSIX timers.Joel Sherrill1999-02-031-0/+6
* Updated to correct information on post switch extension and to makeJoel Sherrill1998-12-171-41/+8
| | | | the user extension table type definition correct.
* Corrected information about the post_switch extension.Joel Sherrill1998-12-171-7/+0
* Spacing.Joel Sherrill1998-10-271-1/+1
* Fixed typo spotted by Jeff Mayes.Joel Sherrill1998-10-091-1/+1
* Added text to clarify the queueing of multiple events.Joel Sherrill1998-08-131-12/+12
* Per suggestion from Eric Norum, went from one initial extension setJoel Sherrill1998-04-151-12/+19
| | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence.
* Went back to not printing an index. makeinfo does fine if you have indicesJoel Sherrill1998-04-022-5/+7
| | | | but do not print them. texi2dvi barfs if the entries are even there.
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-0218-4/+98
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Making the stanza right and improving the way the isntall directories are builtJoel Sherrill1998-03-301-15/+7
* Corrected distribution levels for htmlJoel Sherrill1998-03-301-2/+2
* Added distribution level to each manualJoel Sherrill1998-03-301-2/+3
* Added dependency so html would build from scratch.Joel Sherrill1998-03-271-1/+1
