path: root/doc/user/timer.t (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2008-07-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-07-151-1/+1
| | | | | | | * user/barrier.t, user/clock.t, user/dpmem.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Correct documentation typos noticed and thankfully reported by Fabrício de Novaes Kucinskis <fabricio@dea.inpe.br>
* 2008-04-16 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-04-161-2/+2
| | | | | | * user/bsp.t, user/conf.t, user/init.t, user/intr.t, user/overview.t, user/timer.t: Correct default values. Make it clear that confdefs.h calculates the memory required for you.
* 2007-11-28 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-11-281-3/+3
| | | | | | | | * user/barrier.t, user/clock.t, user/concepts.t, user/conf.t, user/datatypes.t, user/dpmem.t, user/fatal.t, user/init.t, user/mp.t, user/msg.t, user/part.t, user/region.t, user/rtmon.t, user/sem.t, user/task.t, user/timer.t: Corrected various errors in the documentation.
* 2007-10-25 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2007-10-251-4/+5
| | | | | | | * user/barrier.t, user/clock.t, user/concepts.t, user/cpuuse.t, user/init.t, user/intr.t, user/io.t, user/mp.t, user/rtmon.t, user/sem.t, user/stackchk.t, user/task.t, user/timer.t: Updated the Ada documentation to reflect the current binding.
* 2006-09-07 Ken Peters <ken.peters@jpl.nasa.gov>Joel Sherrill2006-09-071-3/+7
| | | | | PR 1171/doc * user/timer.t: Correct documentation for rtems_timer_initiate_server.
* 2004-05-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-05-061-0/+8
| | | | | | | PR 618/rtems * user/clock.t, user/dpmem.t, user/event.t, user/msg.t, user/part.t, user/region.t, user/sem.t, user/task.t, user/timer.t: Add NULL checks.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-16/+232
| | | | | | * timer.t: Added task-based timer information including the new directives rtems_timer_initiate(), rtems_timer_server_fire_after(), and rtems_timer_server_fire_when().
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-0/+1
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Turned on concept and function name indexing.Joel Sherrill1999-10-111-7/+44
* Added "findex" for all directive pages but it turns out that thisJoel Sherrill1998-04-021-0/+7
| | | | blows up both makeinfo and texi2dvi. So I have commented them out.
* Nodes, menus, etc are automatically generated nowJoel Sherrill1998-03-271-106/+3
* Completed sweep adding directive and constant prefixes.Joel Sherrill1998-03-271-25/+33
* Conditionally adding RTEMS_ and rtems_ prefixes.Joel Sherrill1998-03-271-26/+26
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* Added information based on comments from Katsu Shibuya.Joel Sherrill1997-08-041-5/+23
* Fixed typo of "::"Joel Sherrill1997-07-181-1/+1
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-1/+1
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* first cut at Ada bindings manualJoel Sherrill1997-05-291-2/+96
* Initial revisionJoel Sherrill1997-05-271-0/+441
